+ Reply to Thread
Results 1 to 5 of 5
Thread: Muriatic Acid to remove chrome??
  1. #1
    Default Muriatic Acid to remove chrome??
    I called earlier and was told muriatic acid can be used to remove the chrome off metal. The chrome is still there after soaking for some time. It seems like it is flaking a little easier to scrape with a knife, but its not consistent. What am I doing wrong. I thought this stuff would just disolve it away
    Share with Facebook
  2. #2
    Join Date
    Nov 2002
    Location
    Harrisburg, PA
    Posts
    11
    I think you have to use current to electrostrip the chrome off quickly. It is in the manual and the Chrome is very very thin and deplates quickly. Take care not to deplate too much and damage part.
    John
    Share with Facebook
  3. #3
    Join Date
    May 2002
    Posts
    84
    One thing may be a problem, If you have any type of wax or grease on the surface of the chrome, it will not allow the acid to get to the chrome.
    It should turn black and disinigrate off slowely. It wont flake off.
    Try heating your acid in a glass pot. Be really careful not to breath the fumes.
    I heat my muratic/water mix and the chrome comes off almost instantly. It will fiz and when the fizing stops...chrome is gone!
    Dont do this with potmetal parts though.
    48 Buick
    Share with Facebook
  4. #4
    Thanks, I will use this advice in future projects. I ended up primering it to death, then using a black epoxy as the finish.
    Share with Facebook
  5. #5
    Join Date
    Nov 2008
    Location
    Tucson,Az
    Posts
    114
    Thumbs up Re: Muriatic Acid to remove chrome??
    Hello,
    I have been removing plated chrome from nickel using the following:
    Remove chrome plating layer with 30-40 % hydrochloric acid (remember acid into water). You can use reverse current (anode) in the same acid solution.
    For furher information write back on this process.
    Nol4154
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Muriatic acid??
    By lphurley in forum Electroplating Questions
    Last Post: 01-10-2009, 01:08 PM
  2. How do you remove chrome from aluminum wheels?
    By acmepowder in forum Electroplating Questions
    Last Post: 10-01-2007, 05:40 PM
  3. What concentration of Muriatic acid for stripping annodize?
    By athomas in forum Anodizing Questions
    Last Post: 09-14-2003, 02:29 PM
  4. acid damage on triple chrome
    By newview in forum Electroplating Questions
    Last Post: 05-15-2003, 12:04 AM
  5. Remove chrome plating from plastic
    By vdubcoop in forum Electroplating Questions
    Last Post: 08-20-2002, 10:12 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
