+ Reply to Thread
Results 1 to 3 of 3
Thread: Reducing current to auxillary anodes
  1. #1
    Join Date
    Nov 2007
    Location
    Rochester NY
    Posts
    524
    Default Reducing current to auxillary anodes
    Is there anything that can be done to reduce the current a little that is going to the aux. anodes? My main anode read 3 amps, and then when I hooked up the aux. anodes the whole setup jumped to 13! It's still plating fairly smooth and fine grained still, it's just dumping a lot of copper around the aux. anodes (a little too much). I imagine that being so close to the workpiece is the reason for this, and if I drop it down to much, I won't be putting much plate on the rest of the piece. I'm just looking to get a little more even plate. How is everyone else doing this?
    James Bateman
    Share with Facebook
  2. #2
    Join Date
    Sep 2005
    Location
    South Texas
    Posts
    885
    Default Re: Reducing current to auxillary anodes
    Use smaller auxiliary anodes or just raise them out of the solution a little. You just have to watch for shadowing. What's the shape of the plated object?
    Share with Facebook
  3. #3
    Join Date
    Nov 2007
    Location
    Rochester NY
    Posts
    524
    I don't have a pic. of the actual piece, but here's one that is very similar. This one I used aux. anodes with success. I only used them in the acid copper to build in lcd areas so I could sand out the pits. I was okay on the larger flat areas, but the small curved step up section was where I just kept burning through. I didn't pay attention to the amps on this piece, however the area that it was closest to, it burned a hole right through the 1/2" pipe that I was using as the aux. anode. On the piece side, mating to the hole, there was some growths. I'm still calling it a success because I was able to do what I set out to do- sanding down past all the pits that were on the piece. Next time 'round I want to get a little more even plate.
    Quote Originally Posted by CarWiz View Post
    Attached Thumbnails Click image for larger version
    James Bateman
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. How to set constant current (cc)?
    By joelellis in forum Anodizing Questions
    Last Post: 04-19-2008, 02:16 PM
  2. current density
    By fourkbmx in forum Anodizing Questions
    Last Post: 10-27-2007, 01:55 AM
  3. Copy chrome anodes vs. nickel anodes
    By jbvan in forum Electroplating Questions
    Last Post: 01-22-2007, 08:04 AM
  4. Too much current!
    By jeremy5756 in forum Copy Chrome Kit Customers Only
    Last Post: 08-11-2006, 10:50 PM
  5. No current
    By cameraman in forum Anodizing Questions
    Last Post: 12-17-2005, 02:37 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
