Zinc is still the cheapest finish and will go over a polished surface with no problems at all. The final Zinc layer will polish up nicely as a decorative finish without the addition of a chromate finish. It will keep this finish if not handled or subjected to the outside elements. You just need to be careful not to cut through the coating during final polish as Zinc is very soft.
Copy chrome is great as a decorative finish especially if the item is to be kept inside.
Possibly a polished and lacquered copper finish to go with the brass? I have used flash copper for this very reason on an old Kerosene lantern for a work colleague. The trick is to get a good mirror polish on the steel first then flash copper for 15 mins to half an hour followed by a hand polish. I always lacquer my "decorative" parts with clear 2 pac polyurethane. One of the aerosol clear coats will work fine as not everyone has access to a spray booth for use with 2 pac paints.
Hope some of these ideas help.
Cheers... Mark
LinkBack URL
About LinkBacks
