Old 03-10-2002, 02:04 AM
jflev25
Default Plug n Plate
I read that using the plug and plate kit to repair a small rusted area of chrome, you would have to clean out all the rust(of course) and then use copper then Nickel, and copy chrome? I knew that chrome needed a nickel base to work properly but I thought the copy chrome was different. There is no way to just use the copy crome kit? Thanks in advance.
Jim L
Old 03-10-2002, 01:07 PM
mcaswell's Avatar
Caswell Inc Founder
Default Re: Plug n Plate
Sure - you could just use the copy chrome kit, although you might still want a copper plate underneath.
Copy Chrome is very thin, as are most plates. Applying copper before the copy chrome allows you to build up a thick layer of plating to fill in pits and indentations etc.
You can certainly skip the nickel plate if using Copy Chrome.
Have A Web Site?
Old 03-11-2002, 04:03 PM
jflev25
Thanks for clearing that up, I see what you mean. You would get better results starting with the smooth copper plated surface.
Thanks again
Jim L
Plug n Plate Gold over Sterling novenarosary Electroplating Questions 0 03-12-2004 11:00 PM
Plug n Plate lphurley Electroplating Questions 3 09-23-2003 01:15 AM
Plug N Plate Question carmelmike Electroplating Questions 1 03-20-2003 07:10 PM
Plug & Plate a Beltline?? ecoglio Electroplating Questions 1 03-05-2003 07:51 PM
Plug N Plate Copy Chrome question Great_Scott Electroplating Questions 5 03-20-2002 06:53 PM
