Results 1 to 5 of 5
Thread: Nickel Allergy
  1. #1
    catman8_99 is offline Platinum Member
    Join Date
    May 2009
    Posts
    1
    Default Nickel Allergy
    My wife suffers from nickel allergy, which causes severe contact dermatitis. Will the gold plating kits, either 18kt or 24kt, help? In other words, will the nickel from sterling silver or white gold be able to migrate through to her skin?
  2. #2
    lcaswell's Avatar
    lcaswell is offline Caswell Inc President
    Join Date
    Jan 2001
    Location
    Lyons NY USA
    Posts
    643
    Default Re: Nickel Allergy
    The gold will protect her, but you'll have to keep checking the item for signs of wear of the plating. I would say if you have a known allergy to nickel, try to find a different base material to wear.
    Lance Caswell
  3. #3
    woodjames's Avatar
    woodjames is offline Metal Finishing Guru
    Join Date
    Nov 2007
    Location
    Rochester NY
    Posts
    629
    According to wiki-
    White gold contains white metal- either nickel or palladium.
    Sterling silver is an alloy of silver and copper.
    Quote Originally Posted by catman8_99 View Post
    James Bateman
  4. #4
    95gts is offline Amateur Metal Finisher
    Join Date
    Dec 2007
    Location
    Buffalo
    Posts
    68
    Silver and Nickel are like oil and water, you can only alloy them in small quanities and since it so small people usually use it only to harden or bleach the silver. 99% of the time you will not find and Ni in Ag...now white gold try to buy palladium or Platnium rings....another thing they do Is rhodium plate it...but I would just buy different materials , Ni free to start with.
  5. #5
    NOL4154's Avatar
    NOL4154 is offline Amateur Metal Finisher
    Join Date
    Nov 2008
    Location
    Tucson,Az
    Posts
    114
    Thumbs up Re: Nickel Allergy
    Hello,
    Sorry to hear about your wife. I suffer for years with "nickel itch" and spent alot money on doctors and medicine. If she allergic to nickel tell her stay away from it! My wife help me to get rid of this problem with a simply treatment. Squeeze lime juice (the small ones) into a cup; add small amount of sugar until it turns into a paste. Apply it to the affected area and allow it to dry. After about twenty minutes, rinse with clean and allow drying. She will feel the texture of her skin soft. Repeat this treatment until you start see results. It's cheap and at first I did not believe it but now I do and I pass this to people who suffer from this problem. I am a chemist.
    Nol4154
Thread Information
Users Browsing this Thread
  1. How to plate Nickel over old Nickel when steel shows through
    By ASHENASH in forum Electroplating Questions
    Last Post: 04-22-2005, 03:03 AM
  2. Annode Stainless or nickel ? Bright nickel
    Last Post: 04-16-2005, 11:28 AM
  3. gold plate over nickel - do I need to activate the nickel?
    By tbloss001 in forum Electroplating Questions
    Last Post: 01-14-2004, 09:57 PM
  4. electroless nickel vs regular nickel
    By Rocky in forum Electroplating Questions
    Last Post: 07-24-2003, 02:12 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
