I'd go with electroless nickel so you won't have to worry about having to get good connections on a bunch of small parts. Electroless nickel has excellent corrosion resistance.
As to prepping the parts, they must be totally free of dirt, oil, grease, rust ETC. However the metal looks before plating they will look after plating, plating hides nothing.
If the parts are not visible they just need to be rust free and clean, if visible and you want them to be bright then you'll need to polish each part.
LinkBack URL
About LinkBacks
