Results 1 to 2 of 2
Thread: Clear masking material - looking for recommendations
  1. #1
    woodjames's Avatar
    woodjames is offline Metal Finishing Guru
    Join Date
    Nov 2007
    Location
    Rochester NY
    Posts
    629
    Default Clear masking material - looking for recommendations
    Anyone out there recommend a good clear masking material? I've tried frisket film, but the two varieties that I've tried either leave a lot of residue behind, or don't stick at all. I love the way green tape works, if I could find that adhesive with a clear face, things'd be perfect. Ohh, almost forgot, it's got to cut easily too. For example, my hands shake way to much to pinstripe, so I had to cut the white out around the kanji, and spray. So I needed it clear to line things up, and it had to cut well. Wishing I had a plotter.
    Clarification-one of the films that didn't stick to base paint did stick to uro clear. I'm looking for one that sticks to base.
    -Jimmy
    Attached Thumbnails Attached Thumbnails Clear masking material - looking for recommendations-sidepanel.jpg
    James Bateman
  2. #2
    FigureLLC's Avatar
    FigureLLC is offline Metal Finishing Guru Caswell Platinum Member
    Join Date
    Nov 2005
    Posts
    945
    Default Re: Clear masking material - looking for recommendations
    oracal oramask. i like the grey (transparant). comes in different widths. cuts nice (use it on my plotter or free hand), easy to see through, flexible, and good tack level. i get mine from fellers.
    Len
    Figure Finishing
    www.FigureEngineering.com
    866-900-4949
Thread Information
Users Browsing this Thread
  1. New Setup Recommendations
    By Cameratrick in forum Powder Coating Questions
    Last Post: 02-07-2006, 05:02 PM
  2. What is a good material for masking holes?
    By rayginn_mfg in forum Anodizing Questions
    Last Post: 10-29-2005, 03:58 PM
  3. Air tool recommendations
    By SoFlaJim in forum Metal Polishing Questions
    Last Post: 04-17-2005, 06:11 PM
  4. Gun recommendations
    By tinbender722 in forum Powder Coating Questions
    Last Post: 12-17-2004, 10:29 PM
  5. Recommendations?
    By Dugan in forum Electroplating Questions
    Last Post: 01-08-2002, 01:35 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
