if you get one of those electric die grinders , then invest in a variable speed control you will need it . most of my tools are air tools . i think they are lighter and they respond faster to speed change when needed.
i do polishing full time for a long time (maybe too long and i have not used a flex shaft for a long time (many years) . most detail work is done with air sanders and die grinders and most of the larger polishing and buffing is done with my large buffers . i also use an electric angle sander polisher , i have one from dewalt and one from makita , they are very strong , they have a built in variable speed from 0 to 3600 rpm and i can run them with 6 to 8 inch buffingwheels . they are very handy especialy now with larger wheels like 20 or 22 inches and me getting older , now i can do most of the work with the wheel mounted to my workbench |
It's dynamite for car wheels. |
The very first thing you should spend money on is a buffer that will allow you to really lay into it. It'll save a lot of time.
For the engine, with a shaft you are severely limited as to work angles. You can only bend the shaft to a certain radius, then you have to stop and move the workpiece to conform to the shaft's angle. Pain in the @ss. With the die grinder you can move around the piece at will. As for speed, either control the grinder speed for grinding/polishing, or use the drill for polishing. The speed of a drill is fine for polishing. I use strictly cart rolls for intiial grinding - 20,000 - 30,000 rpm is nothing for them. You do need to go a lot slower for greaseless - in that case a drill speed is best. Quote:
you could try and get a flexible drill shaft from Eastwood. 52in Flexible Shaft with 3/8in Chuck-1/4in Arbor it works fairly well, but can only take up to a 4" buff, but it is a lot cheaper than buying an air compressor with a die grinder
I have many flex shafts as well,I find that my 60$ die grinder with 2 inch wheels sove my problems with tight areas,I use a Baldor 3/4 hp with airway wheels to polish fork legs & I'm able to prep & polish completely without breaking out any other tools,and as for your fins on cylinder heads,,try cutting 1/2 the plys away on an airway wheel ,,I do this all the time for getting in tight spaces.
We Dazzle With Brilliance |
| Flex Shaft Parts | junkorgem | Metal Polishing Questions | 2 | 05-04-2008 07:44 PM |
| question on another motor/flex shaft | samtgallagher | Metal Polishing Questions | 6 | 03-17-2008 10:13 PM |
| Buffing speeds & flex shaft? | Tallman | Metal Polishing Questions | 2 | 06-13-2004 01:19 PM |
| Shaft Extenders | Rickc | Metal Polishing Questions | 5 | 04-10-2004 10:40 PM |
| flex shafts | shine | Metal Polishing Questions | 4 | 11-08-2003 02:54 PM |
