Go Back   Caswell Inc. Metal Finishing Forums > Metal Polishing Questions
Connect with Facebook
Old 07-03-2009, 02:39 PM
krazykid is on a distinguished road
Default Polishing a rough cast aluminum valve cover... what tools and where to start???
I am in the middle of a engine rebuild on my car, so while I have all the parts out, I want to polish all the aluminum I can see under the hood. While I am not a total noobie, these are the first cast aluminum pieces I have really dealt with. I did motorcycle frames and extruded or already "flat" surfaces.
I will have a picture of the cover and the other msc parts up tonight. Basically they are rough cast parts. On the valve cover there a lot of deep scratches, and alot of the surface looks like a clay desert dried up. With a lot of little cracks and what not. The casting is just very rough. To make it harder, there are a lot of tight spots and places a da will never touch, and I will just be there all day and burn through tons of sanding drums on my die grinder. I have to remove a lot of aluminum to flatten out the surface prior to buffing.
I just found out about this greaseless abrasive stuff from this website. That seems to sound like the ticket. In my head, 80 grit I know will take alot of the surface down, and the flexible wheel and bobs will get right into the tight spots... but I just don’t know how much material these materials will actually take off.
Where do you think I should start?
Old 07-03-2009, 08:55 PM
baz baz is offline
baz has a spectacular aura aboutbaz has a spectacular aura about
Default Re: Polishing a rough cast aluminum valve cover... what tools and where to start???
i would start with a quick go over with the da so you can see where you can reach and where you can t . for the tight spots i would suggest cartridge rolls .do all the tight spots first then do the larger areas with the da overlapping the areas done with the cartridge rolls
Old 07-04-2009, 12:11 AM
I would start with the "search" thing at the top of the forum...
Old 07-04-2009, 05:03 PM
No ****... If you read my paragraph, you would see that I did quite a bit of searching here, and thats how I found the greaseless stuff. My main question is how much material will this process actually take off?
I cant seem to locate my digital camera at the moment. But here is a link to the cover I am dealing with.
Old 07-05-2009, 12:48 PM
I ordered a ton of stuff.
Greaseless 80 - 400 grit.
The cartridge roll kit and 10 extra rolls.
A bunch of sewn wheels for the greasless.
15 felt bobs.
I actually 2 hours away form them, so UPS ground should only take a day or two. Cant wait!
Old 07-06-2009, 01:27 PM
Easy, junior. If you want help, it might pay to mind your manners.
How much will it take off? You're not getting answers because the question doesn't make sense. It'll "take off" as much as you put time into it. No sh*t.
Old 07-09-2009, 10:55 AM
Sorry but you stepped off the deep end first and used the classic "new guy first post... Reply = "Search button".
I understand physics rather well. I guess the answer I was looking for was something along the lines of "80 grit greaseless on a spiral sewn wheel with light to medium pressure, for 20-30 seconds on a work area will remove aprox how deep of a scratch.
Sorry if I got off on the wrong foot.
Anyway. I received my order yesterday. and the stuff is amazing. I used the 80 grit stuff on a spiral 6" wheel, and used a hairdryer to speed up the layup time on the greaseless. A single application cut down the bare casting on the intake manifold plenum with surprisingly light pressure. in about 5 minutes I covered about a 3X6" area before I had to reapply. I was blown away at how much material it would remove, and yet how flat and smooth it left the surface. in about half an hour I did the entire plenum in 80 and then hit it with the 120. The 120 finish appeared to be what the results of a 220-3X0 grit sand paper would yield.
So far so good, ill post up some pics tonight.
  #8 (permalink)
Old 07-09-2009, 01:30 PM
baz baz is offline
there is no exact science that will say how much material in how much time will be removed , too many variables , type of aluminium castings ,some softer than others , what you call moderate pressure could be light pressure for me , size and width of wheel, speed of wheel ,how dry is the greasless on the wheel , part shape,.
when you change grits try to polish on a different angle when possible , that will help cut the previous polishing lines and it will be easier for you to see if you removed all the polishing marks left by the previous grit
  #9 (permalink)
Old 07-09-2009, 03:49 PM
Very true on the other variables. I guess my initial question was answered by my experimentation with the stuff last night.
i will just continue posting my results here and see what else can be done to improve on it.
The changing my cut directions is a great tip. Thanks!
  #10 (permalink)
Old 10-08-2009, 02:15 PM
magicrat is on a distinguished road
Hi Krazy Kid,
I'm also new to polishing, and want to polish my rough cast motorcycle engine cases. I understand the principles, but how do you use the "hairdryer to speed up the layup time of the greaseless". Any advice would be appreciated, and which grit compounds did you use after the 80 grit greaseless?
Thanks, Magicrat
Can I touch-up this valve cover or do I have to start over? x1rider Powder Coating Questions 18 09-26-2008 07:36 PM
valve cover question superj Powder Coating Questions 3 06-25-2008 02:01 PM
Serious Help Needed, Polishing aluminum valve cover. m3the01 Metal Polishing Questions 29 01-28-2008 12:57 PM
Valve cover polishing-time and effort grommit Metal Polishing Questions 19 12-10-2007 08:54 PM
Aluminum Valve Cover Question ptim Metal Polishing Questions 44 03-23-2007 05:32 PM
