i've had good results with zoop seal. i think it's a silicone/ceramic sealer. supposed to protect aluminum against dulling for 2-3 years, and the sealer doesn't affect the polish (i.e. dull it). i won't lie, it's a pain in the a$$ to use. takes a lot of elbow grease. it's similar to conventional waxing a car. stage 1 is the sealer that you wipe on and let dry. stage 2 is the final sealer that you wipe on and rub and rub and rub to remove the haze from stage 1.
LinkBack URL
About LinkBacks
