Results 1 to 3 of 3
Thread: Polishing Stainless sheet?
  1. #1
    performancepolishing is offline Platinum Member
    Join Date
    Nov 2007
    Location
    Northamptonshire-UK
    Posts
    3
    Question Polishing Stainless sheet?
    Right...could do with some help & info on this...
    Has anyone ever tried to polish stainless Steel sheet with a rotary car polisher..heres why I'm asking..
    I have to polish a sheet of stainless steel to a mirror finish and its way too heavy to hold up to my polishing wheel...at least for any lenght of time.
    So was thinking is it possible to lay the piece down on tressels and use a 240v rotary polisher.....getting the surface up to 1500g first with sandpaper....then not sure what to use as a polishing head...wool mop maybe?...have a few old ones from vehicle polishing...
    Has anyone else had to go this route or something similar...
    Any help would be greatly appretiated
    Regards
    Col
  2. #2
    woodjames's Avatar
    woodjames is offline Metal Finishing Guru
    Join Date
    Nov 2007
    Location
    Rochester NY
    Posts
    629
    Default Re: Polishing Stainless sheet?
    Go for it, I do it all the time for final finish with both nickel and chrome after I plate them, it doesn't leave any where near the marks that a buffing wheel does.
    Here's what I use-
    Dewalt VS buffer - ~1700 rpm
    3M Extra Cut compound - yes for paint - works great!
    3M Swirl mark remover - same thing.
    I use a wool pad, same one I use for paint - just obviously use a dedicated pad.
    I've also done the same compounds with a 3" foam waffle, it leaves more ''evidence'' (fine lines) that it was polished.
    Experiment with other compounds, but that's what I had on hand and was really impressed with the results. Works just as well on copper if you ever come across that. It will dull aluminum that was finished with a blue rouge - but leaves little ''evidence'', but always brings everything else up better.
    The other good thing is that the compound is soo much easier to clean up.
    Quote Originally Posted by performancepolishing View Post
    Regards
    Col
    Last edited by woodjames; 08-21-2009 at 03:34 PM. Reason: i are a english major spellor
    James Bateman
  3. #3
    Join Date
    Nov 2007
    Location
    Northamptonshire-UK
    Posts
    3
    Quote Originally Posted by woodjames View Post
    Here's what I use-
    Thanks James...going to give it a try.. I have most of the farecla range G7, G4, G3, G10 and scratch X so might give them a go first see if they do anything.. I think my polisher will spin up to around 8000rpm I think, so plenty of speed there.
    Cheers
    Col
Thread Information
Users Browsing this Thread
  1. Polishing/Buffing thin stainless sheet stock
    By DoctorFork in forum Metal Polishing Questions
    Last Post: 06-07-2008, 07:22 PM
  2. stainless polishing
    By jaclalo in forum Metal Polishing Questions
    Last Post: 03-29-2007, 08:37 PM
  3. polishing thin sheet metal
    By Rasper in forum Metal Polishing Questions
    Last Post: 09-15-2006, 09:29 AM
  4. polishing s.s. sheet
    By mirrorfinish in forum Metal Polishing Questions
    Last Post: 02-07-2006, 01:42 AM
  5. Copper plating on stainless steel 316L strip/sheet
    By slee36 in forum Services Offered/Wanted
    Last Post: 03-31-2004, 12:46 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
