LOL... Yeah, the black is normal. It's fine metal particles. When you see the silvery-black shine on the buff, add more compound to the buff and keep polishing the heavy scratches out. Let the compound do the work. That's the "color" you're ultimately after on the buff but too soon for now. The course compound and sewn buff you're using will leave a haze (fine scratches). After you have the heavy scratches out and the surface is even, switch to white compound and a loose buff. Same silvery-black will appear on the buff but the part should start to mirror instead of haze. Again, let the compound work and ease up on pressure. Keep applying compound to the buff. When you get the shine you want, a light touch of the buff to finish off should give you the "color" of the metal. You could even go to the blue compound and a soft buff if you're still seeing compound lines. Soft metals take a soft touch.
LinkBack URL
About LinkBacks
yes if you don't have black residue everywhere you are not a polisher.
