Originally Posted by
BroncoCustoms
Hi all,
Not a total newbie to buffing al as I have been restoring/modifying cycles and have done a lot of buffing polishing to bring the shine back to parts with really good success....until now.
I have two struts that I machined from raw aluminum block for a bike I am customizing. I got the al at a local steel supplier. Once the machining was done I sanded everything with 220 until all the tooling marks were gone. This is where it gets funny/strange. On the first piece I was impatient and buffed after the 220 sanding and it looked fantastic!! I noticed it one area I could see some of the sanding marks so I decided I would do it the right way and started over. Sanded with 220, then 600, then 1500. Then I started buffing and was very disappointed. I can't get the same chrome-look as I did before. The finish has a slight cloudiness to it. I even put a fresh wheel on to no avail. I took one part and re-sanded it with the 600 and re-buffed...it looks better but there is still a haze to it that I can't get to clear up. I'm using the white compound w/spiral sewn wheel. I even tried using a loose cotton wheel and that seemed to make matters worse! What am I doing wrong??
