Results 1 to 7 of 7
Thread: improved sanding procedures
  1. #1
    Rasper is offline Experienced Metal Finisher
    Join Date
    Aug 2006
    Location
    Huatulco, Mexico
    Posts
    360
    Default improved sanding procedures
    I mostly polish stainless, which requires heavy machine sanding. My methods have evolved. One has to be creative in this field. Tool manufacturers are not exactly rushing to provide equipment for metal polishers. Here is my latest tool:
    I bought a five inch hook and loop backup pad, drilled a large fender washer to bolt it to, brazed the washer to a 5/8-11 coupling nut, and now I have a five inch pad for that Makita 1400 rpm polisher you see there. I use store bought hook and loop sanding disks up to 150 grit. From there on I cut disks from sheets of wet or dry sandpaper in 220, 400, etc., and glue those to one of the 150 grit hook and loop disks with 3M number 77 spray adhesive. I use motor oil thinned with kerosene instead of water to sand with. Sandpaper seems to last longer with oil. Of course no sandpaper lasts very long on stainless. The stuff eats sandpaper.
    I do the same with a smaller sander:
    It's a Chicago Pneumatics air polisher. It turns at 2500 rpm, and uses three inch disks. This is my favorite tool. I love it.
    Getting stainless ready to go to the buffing wheel is still a lot of work, but these two things sure make it go faster with fewer headaches.
    R
  2. #2
    woodjames's Avatar
    woodjames is offline Metal Finishing Guru
    Join Date
    Nov 2007
    Location
    Rochester NY
    Posts
    629
    Default Re: improved sanding procedures
    Good tips, this could be the start of a good thread.
    To continue on with things -
    After I buff with white compound, I use q tips in a dremel/die grinder to get in all the tight nooks and crannies. I've found the wooden shanked ones, or the plastic stemmed with a drill bit pushed down the hollow center work the best. Both styles yield pretty close to 1/8" shank - which directly "chuck's up" in a dremel, or die grinder smaller collet. I don't even have to apply compound, I just buff with the excess compound that gets built up in the places the wheel won't reach.
    James Bateman
  3. #3
    Join Date
    Aug 2006
    Location
    Huatulco, Mexico
    Posts
    360
    Q Tips! I'll try it for sure.
    R
  4. #4
    baz
    baz is offline Metal Finishing Guru
    Join Date
    Feb 2006
    Posts
    822
    Quote Originally Posted by Rasper View Post
    R
    if you get a machinist to make an adapter that fits your polisher on one side and that fits your sanding pads on the other you could easily change pads witout having to go through that welding part
  5. #5
    FigureLLC's Avatar
    FigureLLC is offline Metal Finishing Guru Caswell Platinum Member
    Join Date
    Nov 2005
    Posts
    945
    i have 5-6 adapters for that chicago pneumatic polisher. i think they came with a 3m hook-it II pad kit.
    Len
    Figure Finishing
    www.FigureEngineering.com
    866-900-4949
  6. #6
    baz
    Join Date
    Feb 2006
    Posts
    822
    Quote Originally Posted by FigureLLC View Post
    i meant an adapter for the bigger makita polisher
  7. #7
    Join Date
    Aug 2006
    Location
    Huatulco, Mexico
    Posts
    360
    For the Chicago Pneumatics polisher, I found some one and one-half inch hook-it pads at my automobile paint store. I bought all they had. That's the kind of thing you see once and then never see again. It had a 5/16 connector so I had to make an adapter.
    Here's the good part: I made a cutting die by forming a circle 1 and 1/2 inches in diameter using a piece of bandsaw blade fastened with silver solder. I ground the teeth off and sharpened the edge. When I wear out a 3 inch disk, I cut the center out of it with this cutter and a mallet and I have a nice new (free) one and one-half inch disk.
    R
Thread Information
Users Browsing this Thread
  1. Wet sanding
    By nfs2000 in forum Metal Polishing Questions
    Last Post: 08-24-2009, 03:52 PM
  2. Improved Anode Bags
    By woodjames in forum Caswell Please Sell This...
    Last Post: 03-22-2009, 09:32 AM
  3. Improved Rinse Tank
    By woodjames in forum Electroplating Questions
    Last Post: 03-21-2009, 09:50 PM
  4. wet sanding
    By sin in forum Metal Polishing Questions
    Last Post: 02-13-2005, 08:18 AM
  5. Sanding
    By squaredealer in forum Metal Polishing Questions
    Last Post: 09-05-2004, 09:06 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
