Results 1 to 3 of 3
Thread: First time Polisher question
  1. #1
    gmann is offline Platinum Member
    Join Date
    Sep 2009
    Location
    Alabama
    Posts
    1
    Default First time Polisher question
    Hello
    I am new to Polishing; I am trying to polish the Stainless Steel trim on a 1947 Plymouth. I received my order from Caswell and started in on one of the larger Pieces the rocker panel. I followed "Polishing Stainless Steel" from this web page as below.
    1st Stage - Rough Cut to Remove Scratches
    Use Sisal Wheel with Emery (Black) Compound
    2nd Stage - Final Cut and Initial Polish
    Use Spiral Sewn Wheel with Stainless Steel (Green) Compound
    3rd Stage - Final Polish (or Luster)
    After stage 2 I had hundreds of scratches on the piece and stage 3 does not remove them. Where have I gone wrong?
  2. #2
    FigureLLC's Avatar
    FigureLLC is offline Metal Finishing Guru Caswell Platinum Member
    Join Date
    Nov 2005
    Posts
    945
    Default Re: First time Polisher question
    they're probably scratches left over from stage 1. if that's the case, do stage 2 more.
    Len
    Figure Finishing
    www.FigureEngineering.com
    866-900-4949
  3. #3
    CarWiz's Avatar
    CarWiz is offline Metal Finishing Guru Caswell Platinum Member
    Join Date
    Sep 2005
    Location
    South Texas
    Posts
    906
    Stage 1 isn't complete until all the scratches are gone. You may have a "haze" left from the coarseness of the black compound but this step is to remove scratches.
    Stage 2 is to remove the haze and get the surface smooth. You should see a high shine by this point an no sign of scratches.
    Stage 3 is the polish.
    If you have access to a DA sander and compressor, mount 400 grit PSA disks and go over the surface to remove scratches. Go to 600 grit to smooth. When the 600 starts to wear, it will polish the surface and you can eliminate Stage 1.
    This starter was done with 400 as you see it. No 600 or polishing yet.
Thread Information
Users Browsing this Thread
  1. New polisher help please!
    By tubthumped in forum Metal Polishing Questions
    Last Post: 03-26-2010, 01:53 AM
  2. my new polisher
    By Rasper in forum Metal Polishing Questions
    Last Post: 01-21-2008, 08:54 AM
  3. what polisher?
    By chiliuno in forum Metal Polishing Questions
    Last Post: 09-26-2004, 07:35 PM
  4. 3/4 hp polisher
    By rida142 in forum Metal Polishing Questions
    Last Post: 05-14-2004, 09:19 PM
  5. I'm a first time powder coater. I have a quick question
    By Silverlex02 in forum Powder Coating Questions
    Last Post: 09-14-2003, 03:59 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
