Results 1 to 8 of 8
Thread: Starting out. This machine worth my time?
  1. #1
    rerod is offline Newbie
    Join Date
    Sep 2009
    Posts
    21
    Default Starting out. This machine worth my time?
    Hi. New here.
    Iv always postponed my polishing projects because I knew I wanted at least 2 hp and prices were high. I just found this old relic and hope I could get your honest opinion if its worth my time. He want 250.. Its 5 hp. 1 1/4 shafts. 220volt
    Thanks
    Attached Thumbnails Attached Thumbnails Starting out.  This machine worth my time?-getattachment.aspx.jpg
  2. #2
    baz
    baz is offline Metal Finishing Guru
    Join Date
    Feb 2006
    Posts
    822
    Default Re: Starting out. This machine worth my time?
    Quote Originally Posted by rerod View Post
    Hi. New here.
    Thanks
    it looks quite rusted but that is cosmetic only ,
    if the motor , and the bearings are good then go for it .
    one of my buffers i bought used 19 years ago (was already a relic back then)and i have been using it day after day on a full time basis since then and can you believe i never had tu put a penny s worth of repair on it .
    best investment i made in my life , that buffer has been bringing in money for the last 19 years.
  3. #3
    baz
    Join Date
    Feb 2006
    Posts
    822
    oh i forgot ,only downside to that buffer could be the shaft size
    caswell carrys buffing wheels for up to 1 inc shafts . you will have to buy from industrial polishing suppliers
  4. #4
    Join Date
    Sep 2009
    Posts
    21
    Thanks. Some of the best machines were the old ones. The motor is almost brand new he said.
    Is that a leather belt?
    Is there such thing as over kill when buying a metal Polisher? Looks like I would need a fork lift to move it.
  5. #5
    FigureLLC's Avatar
    FigureLLC is offline Metal Finishing Guru Caswell Platinum Member
    Join Date
    Nov 2005
    Posts
    945
    yeah, if it's in decent mechanical shape, that'd be a sweet machine. yes, i believe there can be overkill. but if the price is right and it does what you need it to do now, why not allow for some (in this case serious) growth? use extreme caution when using this thing, though. it WON'T stall, and i've heard people describe using 5hp machines as a little scary. i built us a 3-phase 2hp buffer, and i never want for more power with a 12"x4" buff on it. takes a lot to slow it down even with a rake.
    Len
    Figure Finishing
    www.FigureEngineering.com
    866-900-4949
  6. #6
    Join Date
    Sep 2009
    Posts
    21
    Quote Originally Posted by FigureLLC View Post
    but if the price is right and it does what you need it to do now, why not allow for some (in this case serious) growth? .
    He wants $250 obo. New motor and runs well. My only problem is the space needed and getting it in and out of my truck. That thing has got to weigh 500 lbs.
    Where would I buy the buffing disks with 1 1/4" hole?
  7. #7
    Rasper is offline Experienced Metal Finisher
    Join Date
    Aug 2006
    Location
    Huatulco, Mexico
    Posts
    360
    Those old machines are great.
    Go to McMaster-Carr
    They sell flat belts as well. Or you can make one yourself.
    McMaster-Carr
    Turn it kind of slow as those 1 and 1/4 hole buffs are ten inches and more in diameter. If you need to re-pour the babbit bearings, they sell babbit metal too. Lindsay has a good booklet on the complete how to by the Gingery family
    Lindsay's Technical Books
    I am getting ready to pour the bearings in two old cast iron machines I bought for five dollars each, one will be a grinder and the other a polisher. I poured the cutter bearings in a 26 inch planer years ago. Talk about heavy. That was back when I ran a wooden shipyard. I had the best planer in town. I ran it with a 1953 Plymouth engine. It would take a quarter inch off off 20 inch wide white oak flitch in a single pass.
    R
  8. #8
    baz
    Join Date
    Feb 2006
    Posts
    822
    like figurre llc wrote , be careful with those big buffers they can be dangeous .
    i have three large buffers in the 3 and 4 hp range no belts direct drive . one of them running with 14 inch wheels . those monsters can turn any piece of metal into a deadly flying objects faster than you can think .
    as for the 1 1/4 inch shaft buffing wheels they are standard sizes in the polishing industry .
    jackson lea products is one example , if they don t have a location in your area they probably could refer you to one of their distributor in your area
    http://www.jacksonlea.com/
Thread Information
Users Browsing this Thread
  1. (noob?)never pc before - worth it for me?
    By cluap in forum Powder Coating Questions
    Last Post: 06-13-2008, 07:39 PM
  2. Is this even worth trying?
    By ithinktherefore in forum Electroplating Questions
    Last Post: 01-16-2006, 07:45 AM
  3. Can you machine PC?
    By sherilyn in forum Powder Coating Questions
    Last Post: 11-15-2005, 02:43 PM
  4. worth it to create an oven big enough for a car?
    By yerry503 in forum Powder Coating Questions
    Last Post: 08-19-2005, 10:49 AM
  5. Anodizing, Powder Coating ++ Services in Dallas/Fort Worth
    By sgunn911 in forum Services Offered/Wanted
    Last Post: 08-04-2004, 11:32 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
