Results 1 to 3 of 3
Thread: Need Help with tight spaces.
  1. #1
    Crimepays is offline Newbie Caswell Platinum Member
    Join Date
    Feb 2009
    Posts
    27
    Default Need Help with tight spaces.
    I kinda have any idea on where to start but I wanted to see what other ideas were out there for getting into these tight spaces. The piece is aluminum and about 8" x 6". Thanks for any input.
    Attached Thumbnails Attached Thumbnails Need Help with tight spaces.-blower.jpg
  2. #2
    woodjames's Avatar
    woodjames is offline Metal Finishing Guru
    Join Date
    Nov 2007
    Location
    Rochester NY
    Posts
    629
    Default Re: Need Help with tight spaces.
    Start with the crevices, then move on to the flats as it'll help to blend things. I usually use plastic shanked qtips with a drill bit or brazing rod to reinforce them. They are really close to an 1/8" to chuck in a dremel or grinder. Load up with compound and go to town. They're dirt cheap too.
    -Jimmy
    James Bateman
  3. #3
    woodjames's Avatar
    Join Date
    Nov 2007
    Location
    Rochester NY
    Posts
    629
    In addition to that -
    Loose wheels will obviously reach deeper and a spiral sewn, and a narrow wheel will do better than a wide on too.
    "Bias" buffs offer incredible flexibility, and are best for irregular shapes, but they can be a little harder to find.
    -Jimmy.
    Quote Originally Posted by woodjames View Post
    -Jimmy
    James Bateman
Thread Information
Users Browsing this Thread
  1. How do i sand in tight places?
    By thumpinhard25 in forum Metal Polishing Questions
    Last Post: 02-14-2008, 10:03 AM
  2. Skinny buffing wheel for thin spaces?
    By shaunb in forum Metal Polishing Questions
    Last Post: 05-16-2007, 12:47 AM
  3. Need Help with Tight Area's
    By johnny933 in forum Metal Polishing Questions
    Last Post: 09-24-2004, 08:43 AM
  4. Getting into small spaces?
    By berad001 in forum Metal Polishing Questions
    Last Post: 02-07-2004, 12:01 AM
  5. Sanding questions for tight spaces
    By 8mpg in forum Metal Polishing Questions
    Last Post: 02-07-2003, 02:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
