http://www.motoragents.com/pdf/Baldor/VL1309.pdf And would like to use it for buffing chrome parts. The shaft is keyed and 5/8 diameter. Is the Extra Long Shaft Adapters the part I want and which thread? L hand? Is a 8" diameter buffing wheel suggested for the 3450 rpm? Thanks! Last edited by rerod; 09-26-2009 at 12:15 PM. |
I personally prefer a smaller wheel at that speed, but then I usually buff small, complex pieces with lots of edges to catch on the wheel. Try a six and an eight and see which suits you.
R |
The motor is labeled Right hand rotation but thats looking from the rear of the motor. If you look at the output shaft side it spins left hand... So Im guessing I need right hand threads so startup would tighten the nut if it were loose?
Yes, you want the shaft to turn so that it tightens the nut as it turns. If you have a double ended machine you will need one right hand and one left hand threaded end and nut.
R |
Thanks!
Im making a order soon so I have the gear to polish aluminum and chrome. Am I missing anything or buying something I don't need? 6) 80 Ply Spiral Sewn Cotton Wheel 6" 1) Wheel Rake 1) Large Bar Starter Pack includes all 6 compounds 1) White Liquid Rouge (alum) 1) Extra Long Shaft Extender 1) Assorted Felt Bob Kit Basket Total $120.82 Thanks again.. |
I'm not a professional by any means and I'm still learning the art of buffing but If I'm not mistaken, shouldn't you really have a rake for each compound? If I understood correctly from others on the forum, if you use just one rake across all of your different wheels loaded with different compounds, you stand to experience a good bit of cross contamination which of course, is NEVER a good thing. If I'm wrong, certainly correct me as I've been using a different rake for each type of compound to avoid spreading the compound that accumulates on the teeth.
Your list looks good otherwise as a very basic setup . . but I'd just add that it always helps to know what you will be buffing. I think you will find that depending on what you plan on buffing, you will find yourself returning to the Caswell site to order other parts better suited to the particular material you are working with! Good luck and Cheers! |
(* Sets of Wheels.. Depending on what one is buffing, I have found that using multiple 1/2" wide wheels [sets for each compound] to be advantageous.. That is, use one 1/2" wheel to get into small areas, three, four or more 1/2" wheels for wide areas. By using one narrow wheel, one can avoid mashing the wheel and deforming or otherwise tearing it up. Using several wheels for wide areas reduces the risk of "cutting streaks" and it helps to make buffing large flat areas go quicker. In other words, "tune" the width of your wheels to the width of your work. I hope this makes sense). Lastly, keep your buffing wheels and compound bars in "Freezer grade" ziplock type baggies (the freezer grade type is thicker) and label each baggie/wheel with the type of compound used on that wheel (use a 3x5 card), also individually "tag & bag" your compound.. you'd be surprised how quick one can forget which is which.. especially when two different types are the same color! Using baggies also helps to avoid another area of contamination.. plain old shop dust, dirt and debris. I use the "Gallon" size freezer baggies. Use common sense and work-out your own methods and systems..
Charles Last edited by XK120DHC; 10-02-2009 at 03:11 PM. |
| question on another motor/flex shaft | samtgallagher | Metal Polishing Questions | 6 | 03-17-2008 10:13 PM |
| question regarding long storage of solution | aptl1 | Copy Chrome Kit Customers Only | 1 | 07-31-2006 01:45 PM |
| Chrome and Nickel Removal Question (long) | bentley86 | Electroplating Questions | 5 | 03-19-2006 05:32 PM |
| Extra resistance?????? | potsked | Anodizing Questions | 9 | 12-23-2003 03:52 AM |
| Extra Long Shaft Adapters | slick bug | Metal Polishing Questions | 1 | 03-02-2003 10:05 AM |
