Let me just add that while the last compound I used was not made by Caswell, I am interested in what products I should order from Caswell to solve the problem described above.
As mentioned above, the last compound I used was a green bar of "superfine" Chromium oxide that is supposed to be finer than Tripoli.
Thank you in advance for any help . . I'm really stuck here and any help would be truly appreciated
LinkBack URL
About LinkBacks
