You can use a belt sander and about 120grit to get the brushed finish. You can also use a wire wheel on a bench grinder or similar, but it will require a steady hand to get it looking uniform. You can use a standard automotive clearcoat to protect the metal. I have also had sucess with the VHT Clear, however, on an item that large, I highly recommend not using any spray paint type products. If you are looking to paint the desk that color, I would recommend Dupont Centari acrylic enamel. It will require a self etching primer underneath for correct adhesion. You can spray the Centari with a good organic repirator and a cheap spray gun. Centari/Imron is what they use to paint most UPS trucks, so it is quite durable. It will be glossy so a compatible flattener would most likely be required. Again, the VHT that Caswell sells will work, but it is going to take a fair amount of it to complete a project of that size.
Thanks! I'm leaning toward just sanding off the existing chipped paint and see how good I can make it look. But I don't want to sand all the insides of drawers, runners, etc. (not worth the work!)
What type of prep does an automotive clearcoat require? I've seen it in spray-paint form. Is there another way to apply the clearcoat? And would the clearcoat adhere to the existing paint as well as the sanded steel? |
All paint systems are different, therefore I cannot advise. Generally speaking, you can't put an enamel over a laquer, but you can put a laquer over an enamel. The clear should adhere alright to the bare steel. Normally it only requires 320-400 grit wetsand or drysand. I would go with a cellulose based laquer, it should adhere to both the steel and the existing paint.
| Best Clearcoat For Polished Steel | z9ertek | Metal Polishing Questions | 1 | 11-05-2003 04:52 PM |
| Electro-chemical Etching of Steel | Fibergeek | Electroplating Questions | 5 | 07-16-2003 07:38 PM |
| Steel motorcycle frame rust question..... | noob-polisher | Metal Polishing Questions | 3 | 11-08-2002 02:14 PM |
| Question on Satin Finishing a Stainless Steel polished watch | jdavy | Metal Polishing Questions | 2 | 10-28-2002 09:19 PM |
