Go Back   Caswell Inc. Metal Finishing Forums > Metal Polishing Questions
Connect with Facebook
Old 10-17-2009, 10:01 AM
Midilink's Avatar
Midilink is on a distinguished road
Default Polishing Finned Aluminum Valve Covers?
What do you guys use to get in between fins on aluminum valve covers?
Small buffing wheel on Dremel or drill, or large fluffy wheel on your buffer?
Thanks,
Grumpy
Old 10-18-2009, 02:18 PM
baz baz is offline
baz has a spectacular aura aboutbaz has a spectacular aura about
Default Re: Polishing Finned Aluminum Valve Covers?
Thanks,
Grumpy
not knowing the gap in between the fins on your covers i would say the largest buff that will fit in between the fins , if the area in side the fins ie already smooth then you might get away with a large fluffy wheel ,if it is rough then you need a stiffer buffging wheel with greasless compound
Old 10-19-2009, 09:44 AM
Midilink's Avatar
Great, thanks. I'll try the loose fluffy first.
Valve covers> is300soon Powder Coating Questions 5 08-07-2009 04:10 PM
valve covers jw450r1 Powder Coating Questions 5 01-20-2008 08:42 AM
Mickey Thompson Valve Covers asallwey Powder Coating Questions 1 10-16-2007 11:35 PM
intake manifolds and valve covers ? upncoming Anodizing Questions 5 03-20-2005 07:38 PM
valve covers millerperformance Powder Coating Questions 1 02-12-2005 02:08 PM
