hey
i got a question about the greasless compound , im polishing some rims on a gravel truck without takeing them off (done this before) normally i take them off and turn them in my lathe to my desired finish and then polish them , i was thinking if i used the greasless compound on my yellow airway buff with a portable sander polisher vari speed that it might work better for taking out the nicks rather than just starting off with the brown like i always do then to green * its a truck* i just want to know if the cutting abilatys are improved to speed up my process ive got 10 24.5 rims and 5 tanks to do on 2 trucks lol dont mind the typos , Bryonanything on how greasless would cut aluminum on a airway buff would be apreciated ? i could stack a few sisals if it was faster ? |
Greaseless cuts very quickly, but use a light touch or else you can high and low spots which look horrible once polished out, or atleast this is what i have found from experience. I recommend it over hand sanding, or any other method. I use spiral sewn's as they seem to hold it the best. Good luck.
| problems polishing aluminium alloy with white compound | rotorman | Metal Polishing Questions | 6 | 08-02-2004 12:57 PM |
| compound build up | chrisk | Metal Polishing Questions | 5 | 07-11-2004 12:32 PM |
| Cant get compound onto the wheels | 1105 | Metal Polishing Questions | 3 | 04-28-2004 09:05 AM |
| pushing compound about on aluminium | whistule | Metal Polishing Questions | 13 | 12-26-2003 11:32 AM |
| White Compound Turns Black? | GrillMan | Other Metal Finishing Questions | 2 | 08-23-2003 02:12 AM |
