Firescale can be effectively removed with a pickel, but for ss you'd be using a mix including nitric acid, and it's really nasty stuff. You've already stated you want to avoid more tanks.
What about sandblasting? You could set up an appropriately sized cabinet, with dust collection. With the correct media you'd get a decent finish. Ultimately what are you doing with the cages? such as painting/powder coating?
As far as the flux, I've had decent luck using solvents, such as lacquer thinner or naphtha. If you go the blasting route, you'd at least want to remove most of it before bringing it into the cabinet. Blasting can effectively remove traces of flux.
LinkBack URL
About LinkBacks
