Old 08-17-2003, 08:04 PM
shine
Default hand held drill...or 1/2 hp buffer?
hello all. my first polishing task was a set of suzuki sportbike rims,not just
the smooth outer edges might i add.(great first choice )anyway i learned real fast that the rims would take some time to complete.i was despretley
trying to have them completed in time for the 03 riding season.i was able to get somewhat of a fair shine using a 3/8 drill at 1500rpm & 4 in wheels over the course of the summer i have progressed to a 1/2hp
electric motor with one of caswells long shaft adapters.(works great)
i would like hit the rims again in the off season with 1/2hp buffer but not sure if this is the way to go about it.or should i just go back to the drill?
has anyone other than the pro shops attempted something other than the drill?
Old 08-19-2003, 08:15 AM
marsfrogie
Send a message via AIM to marsfrogie
CamaroMike said he holds his wheels up to a stationary buffer, so I suppose it would work just fine if you have decent endurance. A lot of people, use a flex shaft. Flex shaft is my first choice.
Old 08-19-2003, 10:57 PM
shine
thanks for the tip,i did try a flex shaft on my 3/8 drill when i first started the rims.i had no luck,i don't know if it was poor technique or poor product
but all the flex shaft did was kink and break at the end you install into the drill chuck.that was at 1500 rpm,i don't know if i'm brave enough to try that at 3000 rpm. maybe someone has more insight thanks marsfroggie.
Old 08-19-2003, 11:00 PM
marsfrogie
I do agree that you probably had a very light duty flex shaft. They will kink up if they don't have enough of a shell. An angle grinder can be modified to work as well, you will be getting around 8000RPMS, but they tend to overheat.
Old 08-19-2003, 11:18 PM
shine
an angle grinder,you mean the little hand held ones that run off of compressed air?if so, i guess you would have to stop and oil them every 10-15 min.
Old 08-19-2003, 11:22 PM
shine
i don't want to mention the name of the supplier i purchased the flex shaft
from,but all the other products i've purchased have been up to par!!!
Old 08-20-2003, 04:42 AM
spydersac
Send a message via MSN to spydersac Send a message via Yahoo to spydersac
rather a angle grinder you can also get a vari speed electric polisher , usually from 600 - 3000 rpm most comon in body shops and such for buffing paint , i dont think caswell has them that ive seen ?
New 8" Buffer...Now what? tribalimage Metal Polishing Questions 17 03-13-2004 06:42 AM
what speed buffer low900rr Metal Polishing Questions 4 02-26-2004 12:59 AM
