Results 1 to 3 of 3
Thread: Polishing stainless/metal pistols
  1. #1
    jbabb is offline Platinum Member
    Join Date
    Mar 2010
    Posts
    1
    Default Polishing stainless/metal pistols
    I work with Ruger MkII pistols and have been doing some experimenting with polishing. The most I have done so far is with white rouge and a spiral-sewn wheel, but I want to really know and understand how to get a brighter polish and achieve a mirror-finish with these pistols.
    From what I have read, I believe I should start with black/emery compound (lightly), then move to a different wheel using the white/rouge compound, and finally to get that high shine, move to a blue compound and a soft wheel. What tips can be offered for this and what specifically should I seek to purchase as far as wheels and compounds go? How often do I need to scrape my wheel off? I have been polishing for a couple months now using white rouge and the wheel and everything just seems to turn BLACK after a certain period of time. Suggestions?
    I also would like to get a few dremel polishing heads to get inside of the stripped pistol itself to polish internals and make the action smoother
    The majority of the pistol is stainless steel and the frames are mostly sheet metal with most of the small parts being stainless
    Please help me out and thanks in advance!
  2. #2
    Fergman 5000 is offline Newbie
    Join Date
    Mar 2010
    Posts
    18
    Default Re: Polishing stainless/metal pistols
    I used green rouge on aluminum and the shine was grand. However I just found out green rouge is for stainless steel so I would use that. My father makes and polishes knives so that is why I used green.
  3. #3
    Rasper is offline Experienced Metal Finisher
    Join Date
    Aug 2006
    Location
    Huatulco, Mexico
    Posts
    360
    Yes, all hardware store green compound I have seen is for stainless. (Just because it's hardware store stuff doesn't mean it's not good; I have used a lot of it.) From professional suppliers such as Caswell, not all stainless compound is green.
    Emery cuts stainless well at first, but I find that it breaks down too quickly and stops cutting. Stainless compound is normally made from aluminum oxide, which is, I believe, right up next to diamonds in hardness. I recommend getting a coarse and a fine stainless compound. I use only spiral sewn cotton wheels. I prefer to do the major cutting with sandpaper.
    Most of the white compound you see is for final finishing. I use it after the stainless compounds.
    I rake my wheels often—every three to five minutes.
    The unknown here is what kind of finish are you starting with on those guns? Some stainless guns I have seen are so rough that they need some serious sanding. Others are ready to buff. Which is the case with yours?
    R
Thread Information
Users Browsing this Thread
  1. some thoughts on polishing stainless
    By Rasper in forum Metal Polishing Questions
    Last Post: 01-11-2008, 09:30 AM
  2. stainless polishing
    By jaclalo in forum Metal Polishing Questions
    Last Post: 03-29-2007, 08:37 PM
  3. Polishing a stainless gun
    By trade_sniper in forum Metal Polishing Questions
    Last Post: 12-12-2005, 01:27 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
