Results 1 to 9 of 9
Thread: Polishing alloy blower - finished, for now
  1. #1
    vortechyank is offline Amateur Metal Finisher
    Join Date
    Feb 2010
    Posts
    60
    Default Polishing alloy blower - finished, for now
    I was going to edit the other thread, but realised i couldn't, so anyway, here it is.
    My first buffing job from a complete porous cast, i'm really proud of the results for a preliminary polish, but there's a bit more touching up to do, and i'm going to concentrate on technique. Always looking for that better finish. It's going into a race-car and alot of it will be covered, so there are areas i didn't focus on heavily, but once everything else is done it should look nice.
    Finished off with green compound for the shine.
    Process was, black compound with sisal just to knock the cast down and see the surface.
    80 greaseless
    120 sandpaper on a drillbit
    240 on a drillbit
    320 on a drillbit
    A little hit with 400 wet by hand, with soap just to shine up and assess the surface.
    black emery with cloths on a dremel and the angled buff drill
    brown compound with dremel and angled buff drill
    white and a little green mix for the inside on the dremel
    then green all over on the angle buff drill.
    Was basically experimentation just to see what worked and what didnt, i think i have a good process mapped out now for next time.
    The finish rivals chrome but could be a little clearer in places, always trying to improve.
    Appreciate any comments, suggestions or pointers
    Attached Thumbnails Attached Thumbnails Polishing alloy blower - finished, for now-blower91.jpg   Polishing alloy blower - finished, for now-blower2.jpg
  2. #2
    Join Date
    Feb 2010
    Posts
    60
    Default Re: Polishing alloy blower - finished, for now
    Just a few more Appreciate all the help and tips on file here, great help i must say
    Attached Thumbnails Attached Thumbnails Polishing alloy blower - finished, for now-blower3.jpg   Polishing alloy blower - finished, for now-blower7.jpg
  3. #3
    woodjames's Avatar
    woodjames is offline Metal Finishing Guru
    Join Date
    Nov 2007
    Location
    Rochester NY
    Posts
    629
    Great job, no distortion in the reflection. You can see a mile in the thing, and you kept the detail crisp, I'm impressed.
    Quote Originally Posted by vortechyank View Post
    James Bateman
  4. #4
    baz
    baz is offline Metal Finishing Guru
    Join Date
    Feb 2006
    Posts
    822
    yes , nice work you did there . keep in mind that you are working with a casting some casting don t get as shiny as others so it could be normal if in some areas it is not as shiny
  5. #5
    Join Date
    Feb 2010
    Posts
    60
    Thanks guys, appreciate it was alot of work and patience, and to think it had orange peel back after the first step, i was worried then! The Vortech castings are usually pretty good material-wise and polish up nicely, but this one was quite porous in some areas, one area particularly there are still pits. They were right on the surface and are just too deep to sand out, but they hide very well in the reflection/lustre.
    For what it's worth, i cleaned with cool water and soap, using a toothbrush to scrub the fine areas, but i found you really need to hit it with a can of degreaser, to really just blow the crud right out.
    Interesting you say that baz, in the first picture, right where the outlet is at the top, as it curves down, there are these kind of subtle lines that i just can't get to evenly mix in shine with the rest. You can probably 'just' see it. It's nowhere near noticeable, but i was just curious as to why, as it had the same treatment there that the rest of the part received. I guess that's why, some areas just dont get as shiny
    By the way, a question actually - Do you fellows do the soap/degreaser, or just a general clean, after the very last step, and final shine up? I just left this one, because i found if i wet it, and dried it, and then left it to sit, it kind of dulls and oxidizes quicker than if i just leave them with all the buff/wax still on there. Also, an interesting note, a home made metal polish i have actually leaves the surface cloudier, than if i would have just used the metal polish alone. You can rub it on bare machined material and get a mirror shine, but if you follow up compounds with it, it looks notably worse. I think i'll just keep it for rejuvenating the shine on these pieces when they dull, it usually works well in that capacity
  6. #6
    baz
    Join Date
    Feb 2006
    Posts
    822
    i usually clean with very hot water and soap then rinse with very hot water then dry with clean compressed air once you find a good soap stick with it ! be careful with soaps some are too strong and have too much phosphate and can dull the shine , also industrial soaps may have lye or caustic in them and that also can ruin your buffing job.
    i use the liquid sunlight in the yellow bottle works good for me .
  7. #7
    Join Date
    Feb 2010
    Posts
    60
    Cool, i'll give the compressed air a go, i have never done that. Yeah this soap i have rocks! Just a plain yellow stick that REALLY cuts grease with ease, and it actually shines the aluminium up well when you rub it on it. Another liquid soap i have though is, as you say, terrible
  8. #8
    CrazyRay is offline Platinum Member
    Join Date
    Jan 2010
    Posts
    1
    Not bad at all for your first polish job!
    One thing that I've done for removing the buffing oxidation is to put the part in an oven at 225 for about 10 min. I pull it out with gloves and immediately wipe it down with a clean towel.
    If you do another one of these style of superchargers or a turbocharger compressor housing, a buff motor with a rubber expandable wheel and sanding bands will cut your time down by a lot!
  9. #9
    Join Date
    Feb 2010
    Posts
    60
    Interesting, cool tips!
    Thanks by the way too
Thread Information
Users Browsing this Thread
  1. Polishing alloy blower, help needed
    By vortechyank in forum Metal Polishing Questions
    Last Post: 03-25-2010, 04:09 AM
  2. Polishing Aluminum Alloy Wheels? Update After & Before
    By hptech1 in forum Metal Polishing Questions
    Last Post: 08-06-2007, 11:24 AM
  3. will this be suitable for alloy polishing
    By daz2206 in forum Metal Polishing Questions
    Last Post: 01-15-2007, 12:41 PM
  4. Polishing a supercharger/blower
    By 4Lance in forum Metal Polishing Questions
    Last Post: 12-27-2006, 06:46 AM
  5. Alloy wheel polishing questions
    By db_abz in forum Metal Polishing Questions
    Last Post: 08-24-2006, 03:31 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
