Whenever I sand any sort of tube for finishing, the only method I have found that doesn't produce ripples and waves is to wrap the sandpaper around the tube, squeeze hard, and move it up and down the length of the tube. An alternate method would be to use good cloth backed sandpaper and do like a shoe shine boy does with his cloth on the toes of your shoes. You would have to do this near the joints in the frame, obviously, and you could use this method throughout, but sanding along the length of the tubes would be better, give you a smoother result.
A method to remove the waves and ripples you have put in there would be to use a file, cutting only along the length of the tube, never across, until the ripples are gone. Then you would then sand it as I described.
A photograph would help us to give you exact advice.
R
LinkBack URL
About LinkBacks
