Results 1 to 9 of 9
Thread: Problems with Emery buffing
  1. #1
    mainaman is offline Platinum Member
    Join Date
    Jan 2010
    Posts
    4
    Default Problems with Emery buffing
    HI all,,
    I am working on razor restorations, recently got Baldor 1800 rpm buffer to facilitate my work.
    I use greaseless all the way to 600, then Emery. Emery is supposed to remove the 600 grit scratches and leave near mirror finish. To speed up the 600 scratch removal I run the blade at different angles to the wheel. My problem is after the 600 grind marks are removed I am left with fine scratches from the Emery wheel. My question is what is the right way to work with Emery, to avoid my problem?
    Thanks.
  2. #2
    vortechyank is offline Amateur Metal Finisher
    Join Date
    Feb 2010
    Posts
    60
    Default Re: Problems with Emery buffing
    Welcome! Well, from what i understand, the emery is 'roughly' the equivalent of a 400 grit, so i'd say that's where your problem lies straight up, it may be going backwards. After a 600 final sand, it's more than sufficient to move onto say, a brown, or final finishing/color/dazzle compound. Alot of people just recommend the black emery, if you still have scratches afterwards, and it saves a lot of time, but really, if you've done the greaseless well, it should be fine to skip that step in my opinion
  3. #3
    Join Date
    Jan 2010
    Posts
    4
    Thenks, for the reply.
    By brown you mean Tripoli bar correct?
  4. #4
    Join Date
    Feb 2010
    Posts
    60
    Yes, i believe so, i just know it as 'the brown one' hehe
  5. #5
    Rasper is offline Experienced Metal Finisher
    Join Date
    Aug 2006
    Location
    Huatulco, Mexico
    Posts
    360
    I suspect that the emery is not your problem. I find that emery produces a really nice, scratch free finish on aluminum and on steel. You may have some contamination on your buff, or, more likely, you put some scratches in the razor with the coarse greaseless compound that you did not get out with the subsequent finer greaseless compound.
    In my work I find that always this is the case. I get lazy and don't sand as much as I know I should, and bingo: got me again. I have to go back and do it all over again.
    R
  6. #6
    Join Date
    Feb 2010
    Posts
    60
    That could also be the problem, shine some direct light on it from different angles and check to see if there are any small scratches. I would then sand wet in one direction with the 400, then go the opposite direction with the same grit, to try and reveal and scratches that may be there. It won't hurt it, because when you buff it again with the emery, it's the same grit
    Also, are you religiously and surgically cleaning the metal between each (even sanding grit) steps?
  7. #7
    Join Date
    Jan 2010
    Posts
    4
    I use brake parts cleaner after every step.
    I talked to Caswell customer service, and they told me emery is in the 300-400 grit range, so this might be a reason for my problem.
    Tripoli is ~600 grit, White rogue is 800 grit. I will try tripoli after 600 I hope it will work.
    I think that I move to the next grit on greaseless too fast and do not completely take care of the scratches from lower grits.
  8. #8
    Eduardo is offline Platinum Member
    Join Date
    Feb 2004
    Posts
    1
    Cool Re: Problems with Emery buffing
    I do polishing for a living first use the black emery with the sisal wheel after finishing with those, you need to polish them again with a treated vented buffing wheel now using white compound, polish hard and the shine will start to come , Note this is for polishing steel or stainless steel, always use 10 or 12 inch wheels (or bigger) and try to put two or three wheels together to make it wider. If you don't belive me check out my web page Metal Polish and Chrome Services you can call for questions after 4Pm central time ask for Eddie Guzman
  9. #9
    Join Date
    Jan 2010
    Posts
    4
    thanks, I did try sisal and them spiral sewn, both with emery.
    white rogue after that, it is very slow because the wheels are 6" . I am new to this so for now I try to avoid bigger wheels, but definitely will try in the future.
Thread Information
Users Browsing this Thread
  1. Wet sand or emery?
    By sbddvm in forum Metal Polishing Questions
    Last Post: 08-20-2006, 10:31 PM
  2. lingering emery and white spots
    By eyekandi in forum Metal Polishing Questions
    Last Post: 10-10-2005, 07:50 AM
  3. OK...Whats the real deal....Greasless/Emery
    By jhelm in forum Metal Polishing Questions
    Last Post: 03-05-2004, 12:43 AM
  4. Emery vs Greasless
    By bigfishon1 in forum Metal Polishing Questions
    Last Post: 02-21-2004, 02:02 PM
  5. Problems with emery compound
    By hue in forum Metal Polishing Questions
    Last Post: 03-03-2003, 09:31 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
