I'm no pro either, but I wouldn't use the sisal buff. A sewn cotton flannel would work better on aluminum as it won't leave scratches like the sisal and allows you to use more pressure. Also I don't think you need to sand wiith anything higher than 600 grit-Mike
LinkBack URL
About LinkBacks
