Old 09-21-2003, 02:56 AM
Mack_Bolan
Default Clean up
Is there anything I can use to remove the blow off emory compound on the garage floor?
Old 10-19-2003, 11:06 AM
shine
unless your in a pro shop with vents, it looks like your going to have to use a push broom
Old 10-20-2003, 04:12 PM
polishinginc
Send a message via AIM to polishinginc
A good degreaser will remove the laden compound off of the floor. You should get a large rubber mat and place it under your polishing machine.
Old 10-27-2003, 12:26 PM
berndog will become famous soon enough
Send a message via MSN to berndog Send a message via Yahoo to berndog
I use a little aluminum brightener,,,brush in with stiff bristle brush,,,,then go over with powder soap,,hose off then squeegee out
Old 01-04-2004, 04:04 AM
skiddz's Avatar
skiddz
I just wipe it up with a rag and some 409. It probably helps I had my garage floor coated with that epoxy stuff before I moved in tho. hehehe
How 'bout Castrol Super Clean and a stiff brush??? Works good for removing oil drips from the driveway. (One of these days I gotta fix that leak on the wife's car)
Product to Keep Stainless Clean and Polished dschribs Metal Polishing Questions 7 07-16-2005 02:44 AM
How do you clean your polished aluminum? mach1man Metal Polishing Questions 3 10-02-2004 02:42 PM
How do I clean my wheels krsimulis Metal Polishing Questions 11 05-29-2004 09:06 PM
clean that compound! shine Metal Polishing Questions 0 08-19-2003 11:11 PM
How do I clean off the compound? fatalerror Metal Polishing Questions 5 04-29-2003 08:08 AM
