Results 1 to 6 of 6
Thread: HPs vs. WATTs
  1. #1
    pehta is offline Newbie
    Join Date
    Jul 2010
    Posts
    16
    Default HPs vs. WATTs
    Please, enlighten me. On this page I read:
    1/3 HP Buffing Machine
    * 110 volts
    * 3450 rpm
    * 4.2 amps
    * single phase
    * 60hz
    which can be translated into the POWER by multiplying VOLTS and AMPS. So, 110V X 4.2A = 462 WATTs. Since 1 HP is approx. 740W , the power of the motor is 0.62 HP, which is approx. 2/3 HP and not 1/3 HP.
    Is the efficiency of the motor 50% only. I think that electrical motors have efficiency around 80-90%.
    So, please, help me out. What is wrong with my calculation ?
  2. #2
    rerod is offline Newbie
    Join Date
    Sep 2009
    Posts
    21
    Default Re: HPs vs. WATTs
    Not sure.. Why in the world do you need to know?
  3. #3
    Join Date
    Jul 2010
    Posts
    16
    Quote Originally Posted by rerod View Post
    ..... because I am trying to decide which buffing motor I might buy from Caswell. Every motor has, at least two relevant characteristics: power and RPM. Both are important for buffing.
    So, why to buy more expensive 3/4HP motor if the cheaper one has almost the same power (2/3 HP) ?
    This is the main reason why I am asking the readers of this forum to help me out.
  4. #4
    Rasper is offline Experienced Metal Finisher
    Join Date
    Aug 2006
    Location
    Huatulco, Mexico
    Posts
    360
    If you are going to do any serious buffing you want at least 3/4 hp. If you are going to do any really serious buffing you want more. My main buffer is 2 hp.
    R
  5. #5
    Join Date
    Jul 2010
    Posts
    16
    I am answering my own question. Few minutes ago I stumbled upon a nice site (web page) where you can learn about all you want to know regarding electric motors and then more.
    Electric Motor Basics
    Just in case if ( or when) the above mentioned web page disappears, I am attaching the compressed file, which contains ALL the data. Since Caswell does not allow more than 97 KB per attachment, I was forced to split the compressed file into three chunks. This post contains FIRST and the SECOND chunk and the 'step by step' instructions how to reconstruct and read the web page on your computer.
    Instructions are valid for any LINUX or UNIX based machine.
    A) download to your computer ALL three files:
    electric_motor_part_1.zip
    electric_motor_part_2.zip
    electric_motor_part_3.zip
    Assumption: you did download all three files into folder (aka directory) /tmp/
    Open a terminal (aka xterm.konsole,gnome-terminal)
    B) go to /tmp
    cd /tmp
    C) assemble all three files into one. The following command needs to be typed in to terminal as a ONE LINE.
    cat electric_motor_part_1.zip electric_motor_part_2.zip electric_motor_part_3.zip > electric_motor.tar.bz2
    D) uncompress the resulting file
    tar xvfj electric_motor.tar.bz2
    E) start your browser
    F) type into URL field of the browser
    file:///tmp/electricmotors/electricmotors.html
    Enjoy
    Attached Files Attached Files
    Last edited by pehta; 08-23-2010 at 03:24 AM. Reason: For some unknown reason, the attachments were not attached.
  6. #6
    Join Date
    Jul 2010
    Posts
    16
    And the THIRD chunks is here
Thread Information
Users Browsing this Thread
  1. watts = $$
    By EZBake in forum Oven Building Forum
    Last Post: 04-07-2010, 11:25 AM
  2. What size (watts) is this heating element?
    By EequalsMC2 in forum Oven Building Forum
    Last Post: 04-21-2009, 11:32 AM
  3. How do figure how many watts with 240 three phase
    By asalony in forum Oven Building Forum
    Last Post: 05-21-2008, 09:48 AM
  4. Biggest oven with 9000 watts??
    By wetdream in forum Oven Building Forum
    Last Post: 03-04-2008, 11:19 PM
  5. 4x3x7 oven how many watts do I NEED
    By TRAXX in forum Oven Building Forum
    Last Post: 12-18-2006, 05:20 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
