Results 1 to 5 of 5
Thread: lines
  1. #1
    dbt
    dbt is offline Platinum Member
    Join Date
    May 2008
    Posts
    3
    Post lines
    I'm useing a hand held buffer. When I pull the buffer of the part to apply more compound and then get back on my part I can not get exactly back on where I left off. Then I see a line. So how do i remove these lines? Any help would greatly be appreciated!
  2. #2
    rerod is offline Newbie
    Join Date
    Sep 2009
    Posts
    21
    Default Re: lines
    Need more details. Material? Wheel type/speed? compound?
    Sounds like you need to hand sand with 1000 and rebuff and see if the lines disappear.
  3. #3
    baz
    baz is offline Metal Finishing Guru
    Join Date
    Feb 2006
    Posts
    822
    Default Re: lines
    sounds more like buffing line and not polishing lines so i don t think that sanding would fix it .
    if it is buffing lines you could try buffing the whole part without worry about the line then when you are done try to go over the entire part in one shot without stopping . i don t know what kind of part your working on so this might not be possible in some cases .
    another way of doing would be when buffing before stopping try to reduce the pressure on the part a few inches before stopping then when you start again start a few inches back from where you left off and start applying pressure gradually .
    too much compound on the buff or on the workpiece will also increase this line
  4. #4
    dbt
    Join Date
    May 2008
    Posts
    3
    Default Re: lines
    ok baz thanks i'll give that a try! I'm working on a fender for a tractor trailer right now just some scrap aluminum. But I have done a fuel tank also and still see the lines. It seems even if I go really slow I still get lines?
  5. #5
    baz
    Join Date
    Feb 2006
    Posts
    822
    Default Re: lines
    Quote Originally Posted by dbt View Post
    if you can get pictures it would help to identify the problem
Thread Information
Users Browsing this Thread
  1. Why not use 3/4 sch 40 PVC for air lines
    By bikerdad46 in forum Powder Coating Questions
    Last Post: 12-26-2009, 05:09 PM
  2. Reducing the lip from tape lines
    By woodjames in forum Liquid Painting Questions
    Last Post: 06-08-2009, 04:52 PM
  3. Lines left behind........HELP!
    By shoblue in forum Metal Polishing Questions
    Last Post: 10-31-2007, 10:36 AM
  4. heat tape leaving lines
    By l24x4 in forum Powder Coating Questions
    Last Post: 02-21-2007, 12:59 AM
  5. brake lines
    By sageit in forum Electroplating Questions
    Last Post: 03-10-2002, 12:02 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
