stainless is harder than aluminium to polish . needs to be really smooth before buffing stage and yes you can use the stainless compound instead of the black but like i said the part must be real smooth ,anything that you can feel with your finger nail chances are that you won t be able to remove with compound alone .
when buffing stainless you need to generate more heat or friction than with aluminium , more pressure on the work piece along with a stiffer buffing wheel (stacking 2 wheels together can make for a stiffer wheel )and add compound as needed, don t let the part or buffing wheel run dry
LinkBack URL
About LinkBacks
