Results 1 to 4 of 4
Thread: Electric die grinder / more H/D than Dremel tool????
  1. #1
    Join Date
    Apr 2009
    Location
    Conway, South Carolina, United States
    Posts
    26
    Default Electric die grinder / more H/D than Dremel tool????
    I am looking at doing some light duty polishing and need an electric die grinder? or some type of high speed rotary tool that I can chuck a 1/4 inch bit into that will hold a small 3m pad...with sand paper and buffing pads..
    Harbor Freight? Tractor supply?? I'd like something a little more h/d than a dremel but can start with a dremel if needed...
    1990 GT, 347, TFS TW Heads, TFS Cam, TFS Track heat, Twin turbos, FMIC, T5.
    NEW to powdercoating. Still building my setup.
  2. #2
    baz
    baz is offline Metal Finishing Guru
    Join Date
    Feb 2006
    Posts
    822
    Default Re: Electric die grinder / more H/D than Dremel tool????
    Quote Originally Posted by Brads86stang View Post
    if you are into powdercoating than you probably have or will have an air compressor .so i suggest you go with an air die grinder , they are not expensive and they are way more tougher than a dremel ,
  3. #3
    Rasper is offline Experienced Metal Finisher
    Join Date
    Aug 2006
    Location
    Huatulco, Mexico
    Posts
    360
    Baz is right on. I have three of them and they cost less than 100 dollars total for all three. They seem to last forever. I get mine from Northern Tools, their own brand. I like the angle grinders best. The speed is quite variable with air grinders, which is a must for polishing with a high speed tool. Make sure you get one that exhausts from the rear of the tool, not the front, for polishing. You don't want the lubricating oil getting all over your work.
    R
  4. #4
    baz
    Join Date
    Feb 2006
    Posts
    822
    Quote Originally Posted by Rasper View Post
    R
    yes i also like the angle grinder , i have an assortment of die grinder ,1 angle, 3 smaller ones that i use with crtridge rolls and other small tools and 2 larger ones that i use with larger wheels like the 3 or 4 inches . i am using my tools under very high psi 145 to 170 psi ,they don t last as long but they sure have plenty of torque . i do not buy the most expensive brand either .
Thread Information
Users Browsing this Thread
  1. dremel?????
    By j4str in forum Powder Coating Questions
    Last Post: 04-30-2009, 09:20 AM
  2. dremel polishing....
    By tweak in forum Metal Polishing Questions
    Last Post: 02-20-2007, 09:04 PM
  3. Electric die grinder
    By mikekozura in forum Metal Polishing Questions
    Last Post: 03-05-2006, 11:23 AM
  4. Electric die grinder
    By easleysp in forum Metal Polishing Questions
    Last Post: 07-21-2005, 02:15 PM
  5. Dremel
    By GolfNut in forum Metal Polishing Questions
    Last Post: 09-10-2002, 01:11 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
