Results 1 to 4 of 4
Thread: Abrasive Type in Greaseless Compounds? And misc. grit size questions.
  1. #1
    HermanW is offline Newbie
    Join Date
    Jul 2010
    Posts
    7
    Default Abrasive Type in Greaseless Compounds? And misc. grit size questions.
    Does anyone know what abrasive type is in the greaseless compounds? I'm assuming it's aluminum oxide in a wax binder, but I want to be sure of it before buying it.
    Also, I have various buffing compounds, but I've never been 100% sure if I'm using them in the proper order and don't want to end up moving backwards on my own progress.
    Mostly I'm wondering whether the White Rouge or Green Rouge leaves a finer finish. Also whether the White Lightning Stainless is finer than the Blue Begone Liquid Polish.
  2. #2
    Rasper is offline Experienced Metal Finisher
    Join Date
    Aug 2006
    Location
    Huatulco, Mexico
    Posts
    360
    Default Re: Abrasive Type in Greaseless Compounds? And misc. grit size questions.
    As far as white and green go, it depends upon the manufacturer. With the hardware store stuff, Dico, and the other, (I forget the name), white is finer than green. With the professional quality stuff, it all depends on who made it.
    I'm not casting aspersions on the hardware store stuff, by the way; I've used a lot of it with great success. The pro stuff comes in larger bars and is easier to handle, and you can get much more of a variety of compositions. I use a rough cut stainless compound that I love. It's dark gray. Cuts fast and yet leaves no visible scratches. Caswell sells a variety of good ones.
    R
  3. #3
    baz
    baz is offline Metal Finishing Guru
    Join Date
    Feb 2006
    Posts
    822
    the greaseless that i use is made of aluminium oxide but you should check with your supplier because i don t know if all manufacturer use the same .
    the same would apply for your buffing compound , not all companies use all the same color codes . i mostly use pro stuff because of the larger bars and because i get them locally so i don t pay shipping and also because i get better prices when i buy them in boxes of 24 bars.
    the one i use the most is a green bar for stainless steel but i use it all around for stainless , aluminium, and brass*.
  4. #4
    Join Date
    Jul 2010
    Posts
    7
    I'm mostly referring to the ones sold by Caswell(which I would have thought was obvious given where these forums are).
    I did attempt to ask them directly, but so far there hasn't been any response.
Thread Information
Users Browsing this Thread
  1. greaseless vs. cement abrasive system vs. cartridge rolls
    By slow94 in forum Metal Polishing Questions
    Last Post: 07-14-2010, 09:21 PM
  2. Qty in greaseless compounds?
    By Maicojames in forum Metal Polishing Questions
    Last Post: 02-01-2008, 07:00 PM
  3. Greaseless or abrasive ahesive system?????
    By chaotik in forum Metal Polishing Questions
    Last Post: 10-30-2006, 07:08 PM
  4. Greaseless or Abrasive Wheels?
    By mrtace in forum Metal Polishing Questions
    Last Post: 07-19-2005, 04:42 PM
  5. Greaseless Compounds
    By zx7rwinered in forum Metal Polishing Questions
    Last Post: 10-05-2002, 12:06 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
