Old 09-25-2003, 08:51 PM
berndog will become famous soon enough
Send a message via MSN to berndog Send a message via Yahoo to berndog
Default flat aluminum
Would like to hear from anyone polishing dump boxes,,,,what bars & what wheels you would use
Old 10-07-2003, 03:03 PM
I'll try again,,so I am using brown tripoli,with yellow 10"airway wheels,,on an angle polisher at 3000 rpm,and i have trouble with lines ,cloudy lines,,and wondering the best way to get rid of these
Old 10-15-2003, 07:33 AM
breeze
Make sure you are "crossing your lines" each time you drop down to a finer grit/buff. Also make sure before you do this, that all the lines are coming out. Crossing your lines will make it easier to see what you didn't get out at the last step. If the lines are too heavy, go back to a grease belt. Remember, aluminum is very soft and it doesn't take much to put lines back in even when buffing.
Breeze
Old 11-22-2003, 08:58 AM
I'm still looking for a way to get the buff lapmarks & lines out of flat aluminum panels,after cutting with tripoli,before proceeding to green or white.And any tips from anyone on keeping the clouds & lines down when using green or white.Polishing dump truck boxes,,,nothing but a nightmare.
Old 11-23-2003, 08:39 PM
c_gismo
I have never done what you are doing, but I thought the green compound was only for Stainless Steel, not aluminum.
Old 11-24-2003, 08:53 AM
you are right,,,however I've been using green on tanks & wheels for years on truck wheels & tanks,works great there.
Something for you die hard polishers out there to chew on thesound Metal Polishing Questions 15 12-03-2007 12:16 PM
Do you have to use flash copper to plate aluminum krsimulis Electroplating Questions 1 07-27-2004 01:32 PM
flat aluminum berndog Metal Polishing Questions 1 05-16-2004 05:33 PM
Cleaning Oxidized Aluminum With Sand Blasting Media? freematt Other Metal Finishing Questions 2 02-23-2004 02:22 AM
HELP! White haze when degreasing polished aluminum! davidh90046 Metal Polishing Questions 2 10-15-2002 01:19 PM
