i m more the visual type so i usually have to see a pic of the part.
but heres how i think it could be done .
the .032 circles are probably too flexible to apply pressure so holding a thicker similar piece under the circle could give it extra support .
the rings with the hole in it , you could find a round tube made out of wood slightly smaller than your 2 1/2 inch hole ,slip the ring over the tube then hold the tube while you buff the ring . might have to have at least one finger touching the ring to keep it from spinning too fast on the tube . if using large flexible buffing wheels be careful not to let the wheel catch the tube and pull it off your hands .
LinkBack URL
About LinkBacks
