Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By Rasper
Thread: Can you polish different metals on the same buff?
  1. #1
    rifleman is offline New User
    Join Date
    Jan 2012
    Posts
    1
    Default Can you polish different metals on the same buff?
    Specifically: aluminum, steel and stainless steel using an emery compound. Looking to save a little money...
    Also, when ordering spiral wheels, you can choose either 40 or 80 ply....why would that matter?
    Thanks,
    Adam
  2. #2
    baz
    baz is offline Metal Finishing Guru
    Join Date
    Feb 2006
    Posts
    822
    Default Re: Can you polish different metals on the same buff?
    yes you can ,good practice would be to rake the wheel after each use to remove any hard debris that could scratch your work.
    40 or 80 ply refers to the number of layers of meterial that are sewn together, so a 80 ply wheel would be wider than a 40 ply
  3. #3
    Rasper is offline Experienced Metal Finisher
    Join Date
    Aug 2006
    Location
    Huatulco, Mexico
    Posts
    360
    What you don't want to do is to use different compounds on the same buff. Also, the type of sewing matters. For cutting with emery you will find you have much better results using a hard buff, one that has closely sewn spirals. The looser ones are for final work with finer compounds.
    Richard
    Jycorro likes this.
Thread Information
Users Browsing this Thread
  1. scratces after final buff
    By syko4d in forum Metal Polishing Questions
    Last Post: 03-01-2010, 04:01 AM
  2. My first buff and I need major help.
    By Nein-Reis in forum Metal Polishing Questions
    Last Post: 01-22-2010, 02:05 PM
  3. Pre-buff sanding?
    By BobbyIronsights in forum Metal Polishing Questions
    Last Post: 01-29-2009, 01:06 PM
  4. Buff Cleaning
    By shoblue in forum Metal Polishing Questions
    Last Post: 10-21-2007, 06:03 AM
  5. Which Buff and Compound Do I Use? Use Pick-A-Buff Helper
    By mcaswell in forum Metal Polishing Questions
    Last Post: 10-06-2002, 03:51 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
