If you are going to polish welded metal you have to use the same alloy for filler rod as the piece is made from. Every alloy is a different color. I do my aluminum sculpture in 1100 alloy and of course 1100 wire is available. I also use 304 stainless. 308 rod is pink compared to the 304 so I got a local sheet metal friend to slice up a bunch of thin strips of 304 on the shear at the shop where he works. I use that as filler rod.
Richard
LinkBack URL
About LinkBacks
