Old 11-21-2003, 06:02 PM
gjricc2
Default Aluminium Motorcycle Forks
Ok - I'm definitely a rookie when it comes to polishing. I bought a used motorcycle that was left outside for a year. The front forks were pitted. I started wet sanding with 200 grit sand paper and then worked my way upto 1500 grit paper. The pits are gone but I'm unsure how to proceed. Should I now buff with tripoli and then with white rouge? What then? Do I need to seal the aluminium next or can I just leave it as is. I see a lot of references to zoop seal in other forums. I don't want to do all this polishing only to see the results degrade because I missed a step. Help Please!!
Old 11-21-2003, 07:32 PM
tomg552001
Send a message via AIM to tomg552001
Because you sanded up to such a high grit you can probally go right to the brown tripoli followed by white rouge. I myself dont seem to get any good results with brown, so i actually use black emory than go straight to white. After polishing, you can seal the aluminum or you will need to go over it again once it oxidezes. Search around, people have suggested a few good sealers. Good luck!
Old 11-21-2003, 08:24 PM
gjricc2
Thanks so much for the reply. Is polish considered a sealer?
Old 11-21-2003, 08:34 PM
tomg552001
Polishing is mereley a process, and the compounds you use are just tools to get the shine, they wont actually seal it. They are basically a solid block with an ultra fine "sandpaper" if you will substance embedded in it. To seal it you need a actual sealer such as zoops seal or por15.
Old 12-01-2003, 04:56 PM
gjricc2
Thanks again for the help
MOTORCYCLE POLISHING 101 CLASS IS IN SESSION! NautiShine Metal Polishing Questions 61 05-15-2008 03:03 PM
Type of Aluminium. PeterM Anodizing Questions 2 10-14-2004 05:57 AM
NAUTICAL METAL AND MOTORCYCLE POLISHING IN FLORIDA! NautiShine Services Offered/Wanted 5 06-08-2004 08:21 AM
streamlining sanding of cast aluminium parts rotorman Metal Polishing Questions 6 05-22-2004 01:09 AM
Engravings ands anodised aluminium - off the beaten track whistule Anodizing Questions 2 11-28-2003 11:45 AM
