Old 11-29-2003, 02:53 PM
mvallee
Default Removing stains in aluminum
Any tips on removing stains in cast aluminum? After sanding I used a sisal/black compound, spiral/brown compound, loose/white compound but am left with cloudy stains.
Thanks,
MV
Old 11-30-2003, 08:31 PM
shine
hey,make sure you clean the work piece real good before you move on to the next compound,and make sure your applying enough pressure with the buffs.what r you buffing and with what kind of tools?
Old 12-02-2003, 09:04 AM
mvallee
The part is a cast aluminum rear view mirror mount. I wash the part between compounds but might not be using enough pressure, I'll try it again. I'm using a 1/3 hp buffer with 6" wheels.
Old 12-04-2003, 12:50 PM
tomg552001
Send a message via AIM to tomg552001
1/3 hp sounds a little weak for 6 inch wheels, so that may be the problem. How many amp is the buffer?
Old 12-04-2003, 08:42 PM
mvallee
4.2 amps.
Old 12-04-2003, 09:04 PM
tomg552001
I think your buffer might be a little small for the 6 inch wheels and for the purpose of being able to "lay" into the part with some force. What are you polishing? Larger pieces? Does the buffer bind up easy when you put decent force against it?
Old 12-04-2003, 09:16 PM
mvallee
I'm polishing mainly aluminum and stainless trim, nothing too big. I have to put quite a bit of pressure on it to bind with what I'm buffing.
  #8 (permalink)
Old 12-04-2003, 11:20 PM
tomg552001
Hmm yea that will be fine on smaller parts. Make sure you use adequate pressure and use the proper polishing strokes. Against the wheel to cut, and with to polish.
Something for you die hard polishers out there to chew on thesound Metal Polishing Questions 15 12-03-2007 01:16 PM
removing copy chrome from aluminum impactelectro Electroplating Questions 1 03-17-2004 01:49 PM
Removing blistered chrome from aluminum wheels? ozziepartsguy2003 Electroplating Questions 0 12-14-2003 07:26 PM
Removing the chrome surface from aluminum based auto trim jbashaw Metal Polishing Questions 6 10-01-2003 11:20 PM
HELP! White haze when degreasing polished aluminum! davidh90046 Metal Polishing Questions 2 10-15-2002 02:19 PM
