Hmm, To me it sounds like you need to spend more time on the black. Most of your real polishing will be done with the black compound as it is the most coarse. I'd say stick with the black longer and see what kind of results you get. Good luck!
Finally got a few hours to myself today so finished up the cluch cover. Looks good this time around. Used a brand new tight spiral wheel and a heavy hand to cut and very light touch to color. A couple spots have what look like casting striations, but they're on the "bottom" side of the cover so I'm not going to try to work them out. Pics have been posted.
Just for giggles, I test sprayed a small section with VHT clear to see how it would look. I doesn't look too good. Evidently the clear doesn't have much (if any) gloss to it so it kinda dulls the shine of the aluminum.. Not sure if this is a normal pre-cure look or not, but I didn't want to go through the curing stages so out came the laquer thinner to remove it. Zoops is lookin' better and better... |
| Seek replate of 2 new Chrome Showerheads in Polished Nickel | bradesp | Electroplating Questions | 1 | 08-03-2005 10:10 PM |
| Do ALL freshly polished metals rust? | kwood69 | Metal Polishing Questions | 4 | 10-27-2004 12:25 AM |
| How do you clean your polished aluminum? | mach1man | Metal Polishing Questions | 3 | 10-02-2004 03:42 PM |
| Question on Satin Finishing a Stainless Steel polished watch | jdavy | Metal Polishing Questions | 2 | 10-28-2002 10:19 PM |
| HELP! White haze when degreasing polished aluminum! | davidh90046 | Metal Polishing Questions | 2 | 10-15-2002 02:19 PM |
