I WOULD LIKE TO KNOW WHAT IS THE BIGGEST BUFF WHEEL I CAN USE ON A 1 1/2 HP 3400 RPM BUFFER THAT WOULD GET THE BEST CUTTING ACTION ON A ALUMINUM SAND CASTING AFTER SANDING A 400 GRIT?
AND WOULD BIGGER BE FASTER.I AM LOOKING TO BUFF IN PRODUCTION OF ALUMINUM VALVE COVERS THAT CAN BE SEEN @WWW.BULLITTMANS PARTS.COM DAVE |
I'd probally stick to a 8-10 inch wheel, stacked 2-3 deep. How many amp is you buffer? Amps is important as it usually denotes how hard you can lay into the part. I use a 1hp buffer and use 8 inch sisal's stacked 2 deep and get good results, but for browns and reds i use 6 inch wheels stacked 2 deep. Good luck.
In the How to Buff and Polish" guide here:
http://www.caswellplating.com/buffs/...922549ce6821ef There's a small table that gives you an idea on what size wheels you can use with a given HP buffer. I *think* it's almost all the way to the bottom. |
| Chrome wheels have slight rust and little bubbles can I buff | fizlfry | Metal Polishing Questions | 7 | 04-28-2005 02:39 PM |
| Opinions on buff size on a 1 hp machine | easleysp | Metal Polishing Questions | 4 | 04-14-2005 09:57 AM |
| Where to buy buffing wheels | Holmespolish | Metal Polishing Questions | 0 | 04-02-2004 01:53 PM |
| A ? regarding polishing aluminum wheels... | geotexZ71 | Metal Polishing Questions | 4 | 04-25-2003 09:12 AM |
| Does size really matter? | wiggysIROC | Metal Polishing Questions | 1 | 04-01-2003 09:34 PM |
