Buy One, Get One Free Buffing Wheels
Old 12-13-2003, 03:02 PM
Stryder
Default New here, couple of quick ones (yes I read the manual! :-)
Greetings all.
First let me say some of the pictures you all have been posting have been very encouraging and quite impressive.
I had a few quick questions I was hoping someone could answer:
I'm looking at purchasing the 1/3 hp buffing machine here. Will this be suitable for aluminum motorcycle pieces like the Primary cover and such? I'm guessing more power=polish faster?
Has anyone tried clear powder coat over polished aluminum? I'd think it would be quite durable.
The manual says:
"Do not apply the compound after the workpiece, or on its own. This wastes material and is much less efficient. By applying the material before the workpiece, you actually use the workpiece to force the compound into the buff. This is much less wasteful, more efficient and will actually speed up your buffing times."
Does this mean I load the wheel while holding the part to the wheel as well? The last time I tried polishing (in high school granted) we loaded the wheel and then polished the part. How often do you do these 1-2 second loads?
Lastly, I've read several accounts of "black dust", I'm guessing **** flying off the wheels. Is this stuff that's relatively heavy and will not float (thinking maybe shower curtains?) or do I need a positive ventilation system?
Thanks in advance for any assistance.
Old 12-13-2003, 03:43 PM
tomg552001
Send a message via AIM to tomg552001
Welcome to the forum. If i were you, i would pickup atleast the 1/2 or 1hp buffer. The more power (more amps specifically) the more you can "lay" into the buffer which essentially gives you faster polishing times. I have tried clear coating polishing with powder coat, and it is not very desirable. it dulls the polish quite a bit, and when you need to touch it up, it creates a problem. You'd need to strip the powder than repolish. Your best bet is a sealer such as zoops. As far as loading the wheel, i think it means to apply the compound to the wheel itself, and not onto the part instead. WIith black i use a little bit of compound often, and the brown/white i use more compound less often. The dust will get everywhere. Make sure you wear a mask, clothes you dont care about, and prepare for a dirty ceiling, floor, body, everything in the area. Good luck!
Old 12-13-2003, 05:06 PM
Stryder
Thanks a bunch for the fast reply!
On the dust, I understand it will get everywhere thrown by nothing but centrifugal force. What I'm wondering is do I need to completely seal an area or is enclosing a corner of the basement with plastic sheeting enough?
Common sense tells me that the it's wax and grit and it should not float but then again common sense is not my strong suit.
Old 12-13-2003, 05:38 PM
tomg552001
You SHOULD be ok by doing this, but of course the dust will escape from time to time. Just make sure you clean up inbetween polishing and you'll be fine.
Old 12-13-2003, 09:30 PM
Stryder
Awesome, thanks again for replying so quickly.
Old 12-14-2003, 12:27 PM
non-stick
Tom... you can indeed powder coat clear over polished surfaces. You just have to give it a "bath" in something that kills the waxes and organics first is all. I've always found a dip in Hydrochloric (15% solution) works best in these circumstances. Low cure temp on the powder and bring it up slowly to avoid any oxidation and no doubt the results will be a lot more to your liking. Personally I'd use the Zoop but that's just my experience unless you want to clear coat it with a "tint". THEN I'd use a powder coating.
Old 12-14-2003, 12:33 PM
tomg552001
Yes, you CAN powder coat over polished aluminum, but the results are no where as nice as they are with un-clear coated aluminum.
  #8 (permalink)
Old 12-14-2003, 05:57 PM
non-stick
do I smell a challenge between the polishing guy and the powder guy,hummmm? This should be interesting to see a little "brotherly competition" between the Mods,eh? ASSUMING I can..... what are we betting here,hummmm? Caswell.... care to donate a few minor materials so Tom and I can have a little fun? I'll provide the shop (you know where,Tom) and the fair judgement by it's owners (also known by Tom and I'm sure he would have no problems taking thier word on anything in the powder coating field about how aesthetic something looks) all considered by yours truly to be "holy ground". Tom.... you supply a few sacrificial pieces (all the same for comparison purposes please) and I'll supply the process and document the whole thing. Just to keep it fair, only Caswell products allowed for any of it. (except for the hydrochloric acid which I stated above was needed). I can even do it in a true hobbyist playing field and bring it to your workspace if you want the pictures to be judged by all here. This way we all know that results can be achieved in a true hobbyist mode of operation. I say I can make it happen.... still saying I can't? heh heh hehhhhhh
  #9 (permalink)
Old 12-14-2003, 06:02 PM
Fireblade
DO IT!!!! DO IT!!!!
  #10 (permalink)
Old 12-14-2003, 06:10 PM
non-stick
heh.... threaten to spill "blood" and the Romans will always get worked up. I have only one request. I need to do this after the first of the year as I'm in the middle of something HUGE right now and can't be stopped. Other than that..... I leave it up to Tom to accept and Caswell to be the Don King of it all.
Plating Manual?? chromo Electroplating Questions 14 11-23-2005 01:41 PM
Salt Water Rheostat removed from manual? rblmorg Anodizing Questions 1 09-23-2004 06:44 PM
Couple of questions... Bobby-S Electroplating Questions 1 06-13-2004 04:34 PM
