Ok guys,
Im new here !! im a polisher i run a small side buisness and do good work. but im searching for something to make my life easier!! I hand sand all my parts and its getting a little old and tiring!! Thanks for all your help, John H. Forman |
My suggestion is greaseless compounds. They can be applied to a spiral sewn buffing wheel and used on a drill with a arbor. They cut casting extremely fast and a tube lasts forever. You will still need to do some hand sanding to really even out the surface, but it beats doing it from the beginning. Also, for tight crevices check out some felt bobs and maybe some loose/canton flannel buffing wheels and see what works best. Good luck!
Ok well i ordered a whole bunch of stuff from caswell. i got all the greaseless compounds. 180,240, and 400 now my question is how do i apply this stuff?! i have no experience with the greasless compounds and i was wondering if anyone can offer thier input on using this stuff. i bought felt bobs to get the tight places. im really interested in seeing what others do for polshing all replys are greatly appreciated !!
The greaseless compound should be stored in a air tight container with a wet rag to keep them from drying out. To use them simply rake out a spiral sewn wheel than run the compound on the wheel until it starts taking. If using a drill you will need to apply pressure and go part triggor on the drill to turn it slow. You'll see it eventually taking to the wheel. Once its dried and hardened go to work. Good luck.
*MY* work? I've got a few interspersed with my 4 wheeler rebuild pics here:
http://www.net-cetera.com/banshee I've got more I haven't sucked outta the dig-cam yet but as I get to 'em, they'll be posted. Workin' on touching up the reassembled engine and will get pics of that up probably Sunday afternoon. |
| Something for you die hard polishers out there to chew on | thesound | Metal Polishing Questions | 15 | 12-03-2007 01:16 PM |
| Polishing cast aluminum | turbohardtop | Metal Polishing Questions | 26 | 07-05-2005 11:10 AM |
| Cast Aluminum | scocklin | Anodizing Questions | 5 | 12-04-2004 12:38 AM |
| anodizing cast aluminum | 8knots | Anodizing Questions | 2 | 06-05-2003 09:27 AM |
| Cast Aluminum | Dexter | Anodizing Questions | 0 | 08-20-2002 03:28 AM |
