  #11 (permalink)
Old 12-25-2003, 03:54 PM
customandsound
Guest
Posts: n/a
the pads i got from home depot are junk the did a little cutting but they fall apart the part looks ok but not what i want ... it had a lot af cast marks to start with but i just started with a buffing wheel and compound i should of sanded it them went to compaound ....
  #12 (permalink)
Old 12-26-2003, 11:37 PM
customandsound
Guest
Posts: n/a
well i resanded and went over with a new set of pads and i got a nice shine going .. but i still got marks from the old casting ..... i am converting a old motor from my lathe and then try it again .... i will put a pic on in a few days of the before and the after .... this is my first project that will end up on my car .... i still got the whole top end and other parts to go .....
  #13 (permalink)
Old 12-31-2003, 11:49 PM
customandsound
Guest
Posts: n/a
i put a pic of the few things i polished in the gallery part of this forum ... they are ok but i still need to work on them more ... thanks for all the help so far
  #14 (permalink)
Old 01-02-2004, 08:08 PM
customandsound
Guest
Posts: n/a
what is the fastest cutting compound that caswell sells that will work on alumin.and what size wheel should i put on a 1hp motor?
Something for you die hard polishers out there to chew on thesound Metal Polishing Questions 15 12-03-2007 01:16 PM
STRIPPING PAINT OF METAL BEFORE POLISHING IT BRANDONPEAKE Metal Polishing Questions 7 02-05-2005 12:25 AM
Metal Polishing Questions for Nickel Plating pelletman Metal Polishing Questions 3 07-31-2004 03:09 AM
NAUTICAL METAL AND MOTORCYCLE POLISHING IN FLORIDA! NautiShine Services Offered/Wanted 5 06-08-2004 08:21 AM
polishing metal gopedhead Metal Polishing Questions 8 04-30-2002 05:33 PM
