hello there ... i am new to this metal polishing thing and i want to add it to my list so my customers have another choice .... one thing i need to know is what are the rates on the basic stuff... and is there a place i can get them from ... i am working on a set of valve covers seeing how they are small and using the wet and dry sandpaper route they are looking ok but not what i want i will put a pic on later ....
well i just got back from the local home depot and i got a 8 pc kit it has 3 pad's and 5 sticks of compound... and a arbor for a drill is that a good kit to start with ? and where can i find a arbor to convert a dual shaft motor in to a buffer at ... or should i just set up a jack shaft and run 2 wheels at one time ?any input will be helpful.... thanks
You will need to use a buffing wheel. I tried the home depot stuff when i first started polishing and they're horrible and exspensive. Caswell also sells extender shafts for the motor to make them into a buffer. Good luck.
There is NO one on the internet that can beat caswells pricing on buffing wheels. Trust me, i've searched high and low, and i personally havnt found anywhere. Thsoe Home Depot ones are horrible though, especially the loose wheels. They fly apart within 5 minutes of using them especially if you use them on a high speed angle grinder.
| Something for you die hard polishers out there to chew on | thesound | Metal Polishing Questions | 15 | 12-03-2007 12:16 PM |
| STRIPPING PAINT OF METAL BEFORE POLISHING IT | BRANDONPEAKE | Metal Polishing Questions | 7 | 02-04-2005 11:25 PM |
| Metal Polishing Questions for Nickel Plating | pelletman | Metal Polishing Questions | 3 | 07-31-2004 02:09 AM |
| NAUTICAL METAL AND MOTORCYCLE POLISHING IN FLORIDA! | NautiShine | Services Offered/Wanted | 5 | 06-08-2004 07:21 AM |
| polishing metal | gopedhead | Metal Polishing Questions | 8 | 04-30-2002 04:33 PM |
