  #11 (permalink)
Old 12-29-2003, 11:36 PM
gopedhead
Send a message via AIM to gopedhead
i dont think so, i buffed hard enough to bring a shine, just can't get the haze out or the scratches. i've been told to go bigger, that is why i'm thinking of the 12 inch loose cotton. i dont have 300 bux for a grinder. or buffer. if someone can link me to ebay w/ a good used one or new one, i'd appriciate it.
  #12 (permalink)
Moderator
bhhodges is on a distinguished road
there is no possible way your going to be able to use this machine with a 10" or 12" wheel . when you use the 8" with no problems as you say---the grinder has to bog down if you press into the wheel with the item your buffing right??
bill
  #13 (permalink)
Old 12-29-2003, 11:38 PM
gopedhead
not noticable when i do press down on it, i dont press down lightly either , at least 10 pounds pressure.
  #14 (permalink)
tomg552001
Send a message via AIM to tomg552001
The reason you probally cant get scratches out are you can't put enough pressure to get a good cut, and from my experience a haze can be caused with lack of speed and power aswell.
  #15 (permalink)
gopedhead
i think
  #16 (permalink)
Old 12-29-2003, 11:40 PM
tomg552001
2 amps is too little. It will work, but you'll buff faster, and more effectivly with a bigger buffer with the same wheels. I first started with a 2.4 amp grinder, and i couldnt put hardly any prssure on it without bogging. What kind of parts are you polishing?
  #17 (permalink)
gopedhead
where can i get a good grinder for a cheap price, under 50 bux. pereferably. (ebay maybe?) any brand suggestions
  #18 (permalink)
Old 12-29-2003, 11:42 PM
tomg552001
Caswell has a selection of buffers, or check out ebay. get something atleast 3/4HP and 8+ amps for your 8 inch wheels.....than get some extender shafts from caswell.
  #19 (permalink)
tomg552001
Also, remember you get what you pay for.....i have sure learned that the hard way! :P
  #20 (permalink)
gopedhead
i'm polishing smll parts. probalby area of. 2.5 x 4.5 inches....
less than that. the most of that part is: 1.5 x 2.5 inches.
if u're familiar w/ a goped, it's the part on the engine that holds the pullstart. its a plate.
anno power supply jasonboulanger Anodizing Questions 2 01-07-2005 06:48 PM
Power Supply Question edwin247 Anodizing Questions 5 08-30-2004 12:20 PM
Modding a bench grinder, would this work? berad001 Metal Polishing Questions 2 01-06-2004 08:45 PM
Anodizing Power Supply Q's jnbsystems Anodizing Questions 7 10-02-2003 11:33 PM
Power Coating Rick M Powder Coating Questions 1 03-13-2002 05:38 PM
