I guess I ranted prematurely. When I got home from pickin' my kids up from school this afternoon, there was a big ol' box on the front steps. Lo and behold, it's my buffing machine. Leaving the kids to haul their **** in from the truck on their own, I grabbed the box and headed to the garage.
I opened up the box and my 1st impression was "Holy [bleep] is it big!" The motor is about 8" in diameter and the shafts are about 12" long - 10" of 1" diameter with a 2" section of 5/8" thread. Right side is standard thread, left is reversed. Came with a bunch of different collars and two wrenches to secure everything in place. Fairly heavy unit - probably about 60-65 lbs - and covered in anti-rust "funk" (Which didn't help the right side shaft much. It's got a good rust stain on it I'll have to attack with some steel wool) The base is pretty wide and has rubber feet on it and there are 2 3/8" holes for mounting to a base or your bench.
I pulled it out, set it on the ground, wiped all the anti-rust stuff off and plugged 'er in. Hit the switch and was met with nothing but a loud humming - right up until the breaker popped about 1.2 seconds later. What the &^$%#!??
I reset the breaker and tried spinning up the shaft by hand before hitting the switch again. (thinking it just needed a little help to get moving since it was new) Again with the hum, but this time I managed to shut it off before the breaker popped. Now I was more than a little perturbed..
I thought the thing was maybe wired for 220 instead of 110 like it said on the power cord tag so I rolled it on it's side, pulled the base cover and checked it out. Nope. Wired for 110 alright. Then I noticed the big capacitor with the protective cover partway off it's top terminals. Sure enough, one of the wires had popped loose. (Not a good thing on a capacitor start motor)
I shorted the terminals together with a screwdriver to make sure there was no charge in the cap (there wasn't) then secured both wires to their respective terminals. Put the cover back on, plugged her in and hit the switch. Woohoo! She's spinnin' and quiet as a fart in church!
I didn't get a chance to give 'er a test run as I had to get the kids going on their homework, dinner and showers.. Won't have an opportunity to try it out until tomorrow afternoon, but grabbing a shaft with a gloved hand didn't slow it at all - just heated the palm of the glove up in rapid fashion. Seems to have plenty of grunt. Guess I'll find out tomorrow.
Oh customandsound, the motor's label says it pulls 8A, not 16 like the guy at Jet said. Two wirenuts is all you'll need to touch to wire it for 220V operation. I'll let ya know how it works once I've given it a proper thrashing.
