+ Reply to Thread
Page 2 of 3
FirstFirst 1 2 3 LastLast
Results 11 to 20 of 30
Thread: Serious Help Needed, Polishing aluminum valve cover.
  1. #11
    Join Date
    Dec 2002
    Location
    NJ
    Posts
    283
    You dont need to use the kerosene for the polishing compounds. He suggested it for sanding as a lubricant to aid the cutting action of the paper. Start with a lower grit paper and slowly work your way up to a 600 or so. At that point get on to the compounds. i'd say 75 percent of the polishing will be done with the black emory and sisal wheel. Experimentation and time is the best way to find what works better for you. I feel your first step should be to get a suitable bench top buffer or sorts. Good luck!
    Share with Facebook
  2. #12
    customandsound Guest
    Quote Originally Posted by m3the01
    Do i just put it on the valve cover then start sanding? How much>? Also do i use the kerosene when i using the black polish on the sisal wheel? Or only when sanding? Start at lower grit then work my way up right? Once it velvety start the polishing? When to switch compounds, when she's blinging?
    Also can i use a dremel with the little sand paper disks/rubber wheel with sanding pad or only a block?
    How do you sand those hard to get area's?
    thanks,
    Steven
    when you sand it then buff it you shold get some thing like this
    but i got brushed alum. top .... it is my best yet
    Share with Facebook
  3. #13
    How did you get into the bolt holes?
    Also, should i use a block and paper approach or use a air pencil 70000 rpm with the little band wheels. They come in 80 all the way up to 600
    Let me know, thanks,
    Steven
    Share with Facebook
  4. #14
    little dremel buffing pads .... just block sand then buff ... sears got 3/4hp bench grinders on sale pick one of them up and for the buffing part ... the little sanding wheels take to much metal off it makes it all wavy ... i blasted it wet wet sanded from 100 to 600 then went to black then brown then white ...... what are the cover off of you are doing ?
    here is another one of some parts i did
    Share with Facebook
  5. #15
    Thats unreal.
    But seriously when im hearing block sanding and going from 100-600 im in disbelief. When you say block sanding im thinking hand sanding on a block. But still how do you get into those little area's with the bog block sander?
    How long would a valve cover take from start to finish? Its off a eclipse.
    thanks,
    Share with Facebook
  6. #16
    Also what did you mean by you blasted it?
    thanks,
    Im going to get the Bench grinder and some wet sand paper from 100-600. I still dont see how you used buffing pads in those tough areas because its still raw aluminum in htere for me so buffing pads wouldnt do anything
    thanks
    Share with Facebook
  7. #17
    email me customandsound@yahoo.com .... if you got a pic of it send it over
    Share with Facebook
  8. #18
    Well i bought a bench grinder 1Hp 8 inch 3500 rpm from Mastercraft. Three year warranty 7 amps 69 dollars canadian. They listed it wrong online its 100. Used it with the 4 inch wheel and it work like a charm. Im going to buy 3 8 inhc wheels then i should be smoken. Also sanded it down with 120. But i guess i real made a mess of it used the 70 rpm air pencil, should clean up good though.
    How do you get in all those really tight places. The flat palces are blinging.
    Steven
    Share with Facebook
  9. #19
    felt bobs from caswell .... i got a bunch of them cheap wheels from home depot .. but for them spots i used buffs on a dremel ... i did another one today ... i wet sanded it up to 2500 grit hit it with white compound .. and it dose not look as god at the one in the pic ......i am learning alot of tricks i will pass on as i learns alot by just asking and then going and doing it
    Share with Facebook
  10. #20
    so how did it turn out ?
    Share with Facebook
+ Reply to Thread
Page 2 of 3
Thread Information
Users Browsing this Thread
  1. Something for you die hard polishers out there to chew on
    By thesound in forum Metal Polishing Questions
    Last Post: 12-03-2007, 12:16 PM
  2. aluminum polishing needed
    By toxicd in forum Services Offered/Wanted
    Last Post: 08-21-2005, 02:10 PM
  3. input on aluminum polishing and need help choosing a buffer
    By Sid03 in forum Metal Polishing Questions
    Last Post: 08-09-2004, 10:21 AM
  4. Aluminum polishing help needed
    By erikchow in forum Metal Polishing Questions
    Last Post: 02-25-2004, 02:44 AM
  5. A ? regarding polishing aluminum wheels...
    By geotexZ71 in forum Metal Polishing Questions
    Last Post: 04-25-2003, 08:12 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
